6320 Hyd return
/ 6320 Hyd return #1
Robertb
Hi . does anyone know where to connect free Hydraulic return on 6000 20 series . i am running hyd motors that need free return (not through remotes). 6000 10 series has a port but 20 series have changed ! Any thoughts ?
regards
Rob.B
/ 6320 Hyd return #2
They should have the new "power beyond" kit that has the regular loop that intercepts the full pressure line from the pump to the rockshaft. Plus it has a third line that dumps directly to the sump. That third port is where you want to connect your open return.
I have seen this on 3x20,4x30 and 5x20 so I am assuming it is the same for the 6x20.
/ 6320 Hyd return #3
Can you tell me where the 3rd port on 3x20 enters the sump? I have no power beyond but need to run a zero restriction return on my Clemens weeder. I can't find pictures anywhere.
/ 6320 Hyd return #4
regards
Rob.B
On your rockshaft valve, as viewed from the back of the tractor, you want the right port. It has Plug Key 1 and O-ring key 2 in the drawing.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A66734)
2025 Kivel 48in...
SKIDDED STEEL ROLLER (A68842)
SKIDDED STEEL...
2021 Weber CF 2-IIHD Plate Compactor (A61572)
2021 Weber CF...
2015 Kenworth T800 T/A Wet Kit Sleeper Cab Truck Tractor (A64194)
2015 Kenworth T800...
2017KENWORTH T270 SERVICE TRUCK (A65057)
2017KENWORTH T270...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
