Sprayer: 3pt or UTV?
/ Sprayer: 3pt or UTV? #1
gstrom99
Elite Member
Butler County, Iowa
Deere 855, Deere 530R zero turn, Allis Chalmers D17 III, Polaris Ranger, Deere 3032E (SIL's), Yamaha Timberwolf 250, Husky saws, H & H 10k and Carry-On trailers
I have a FIMCO 3 point 45 gallon (2.4 gpm pump, 4 nozzle) sprayer I use on my compact tractor for ~20 acres of food plots, probably two or three times a year. I'm considering going to a 65 gallon (4.5 gpm, 7 nozzle) sprayer for my Polaris Ranger UTV. The 3pt tractor one works OK, but is bouncy and slow, and only 45 gals. The UTV is easier to tow to the plots with my Jeep (vs using the big trailer and truck for the tractor) would be faster and has a better ride. People poo poo FIMCO, but my experience with them has been very good.
Would it be worth spending $1k, for an upgrade?
/ Sprayer: 3pt or UTV? #2
I wouldn’t be concerned about the Fimco brand. I think they’re all about the same anyway. If it makes it easier to transport and get the job done, go for it.
/ Sprayer: 3pt or UTV? #3
I have a trailer sprayer. I like that I can hook it up to my Mule, my truck, or one of my tractors. I also like that I can park it out under a tree and let it sit until I use it again. It's not something that is used very often, so having it out of the way for most of the year is a big plus.
/ Sprayer: 3pt or UTV? #4
I love my 3pt Fimco sprayer, and would never want to go back to a tow-behind sprayer. That said, I did have to mod mine to put the controls within reach, as having them mounted near the top link connector was too far away to reach on my tractor. Not a big deal, and anyone can run some longer hose extensions to remote that valve anywhere they'd like, or even just switch the pump on and off with an inline cord switch, like most of the tow-behinds do.
I don't understand anyone prioritizing the ability to tow it with vehicles other than their tractor, if they own a tractor. Having the ability to use 3-point implements, rather than crappy tow-behind toys, is part of the reason I own a tractor! :p
/ Sprayer: 3pt or UTV? #5
Although you are doing more serious spraying than I do, here is one recommendation. A sprayer mounted ON the tractor makes it very nimble. There's never a problem with short tongues, jackknifing, etc. So far the best for me is the one on the forks. No looking back to watch the liquid level or coverage pattern.
/ Sprayer: 3pt or UTV? #6
Are you considering a tow-behind? Or something mounted in the bed of your UTV?
I would say that a 65 gal mounted in the bed would be a good idea for food plots. I would not consider a tow-behind for food plots.
I have a 50 gal custom made tank in the bed of my Gator UTV. I use it for spraying sports fields. And I probably spray 100 acres or more each year. but this rig is not for food plots because my Gator has turf tires and is 2 wheel drive.
When I did food plots a few years ago, I had both a 30 gal. and a 15 gal tank mounted in the back of my Mule ATV. I would mix my herbicide in the 30 gal tank and when it was empty, I would pump from the 15 gal into the 30 and mix more, or use it to rinse. I always kept fresh water in the 15 gal.
I also had a single broadcast spray tip mounted about 3' above the bed of my mule. Sometimes the vegetation in our food plots would get 6' tall or more, and this allowed me to get my spray up over that. That single tip would spray about 18' wide.
/ Sprayer: 3pt or UTV? #7
Read the original post. He’s wanting to put it on his ATV cause it’s easier to transport to remote locations and faster, less bouncy spraying when he gets there.
I agree that 3-point is way better for me than tow-behind too. But that’s not the question here.
/ Sprayer: 3pt or UTV? #8
Agspray is Fimco's commercial line. There is a considerable difference regarding quality of parts and serviceability.
/ Sprayer: 3pt or UTV? #9
Maybe he’s looking at Agspray. That would seem to fit the $1000 price tag closer than Fimco.
I find most of my sprayer problems are self inflicted. I snag the boom on a fence, let it freeze and bust a fitting (almost always breaks the filter screen housing first), etc. — for the most part easy to service and replace everything including the pumps. Wands seem to have only about a 2 year life. The tires and wheel bearings on the small tow sprayers are constant trouble. Much better to lose them and carry it in the bed or on a 3-point. I stripped one down and strapped it to a carry-all frame. Another option to eliminate wheels and tires.
/ Sprayer: 3pt or UTV? #10
As a homeowner with few acres to maintain I obviously do spraying on a lot smaller scale.
Here is my FIMCO 25 gallon sprayer with Chapin spray boom DIY setup on set of wheels which is towed behind old ATV.
Used it two days ago with only one active spray nozzle to spray blackberries etc. along a fairly long fence-line.
With two nozzles it can spray 7' width according to Chapin and is working very well for our needs.
The wheels etc. are what's left of busted fertilizer spreader.
/ Sprayer: 3pt or UTV? #11
View attachment 5802556 View attachment 5802554 View attachment 5802555
Gotta say, that’s unique. Never saw anyone have a tow caddy for just the boom!!
:D
/ Sprayer: 3pt or UTV? #12
Great idea! Now you don't have the entire sprayer back there being beaten up with bumps etc., just the boom. I could see this being useful for a situation (like mine) where I need two different kinds of spray booms - single nozzle that sprays 16 foot pattern for the yard and the tow-behind with panel on one end for spraying the driveway.
Instead of two complete sprayers to maintain (and winterize) just use one and employ the tow-behind boom as necessary.
Thanks for the replies. Yes, it would be IN the bed of the Ranger. I could put the current one (with tank and 3pt frame which makes it alot heavier - maybe take the frame apart?...) in the bed and order a boom kit that mounts in the 2" hitch ($250 @ TSC), and adapt the electric switch to the cig lighter. I might try that, before spending $1k (FIMCO - not Agspray). The new one would have the added benefit of larger tank, boom and pump though...
/ Sprayer: 3pt or UTV? #14
The frame doesn't weigh much.
/ Sprayer: 3pt or UTV? #15
I use a Chapin Mix on Exit model in the bed of my SxS. It has a boom and a wand. We use it for watering on remote parts of the property and for spraying herbicide along the fence lines and such.
I can run it off of an RV battery or directly from the 'lighter' jack on the SxS (with adapter).
There are places my tractor can't go that my SxS can easily. Using my tractor would be a waste of diesel. YMMV.
/ Sprayer: 3pt or UTV? #17
In my opinion I'd stick with the 3pt on the tractor, mainly because you have a 540 PTO there and can run a 6 roller pump, instead of the electric ... The roller pumps are MUCH longer lasting and dependable than the electrics ...
I run a 6 roller pump on my 65 gallon 7 nozzle boom sprayer ... Almost 10 gallons a minute, up to 150 psi ... FIMCO 65 Gallon 3 Point Complete with 6 Roller Pump and 7 Nozzle Boom
/ Sprayer: 3pt or UTV? #18
Same exact sprayer and pump I'm running. Works great! I did swap the nozzles to hit the target rate for most of the product (turf pesticides) I'm putting down.
/ Sprayer: 3pt or UTV? #19
:D
Thanks,
I wanted to use the existing sprayer for boom spraying as is, but instead of mounting the boom in the back of ATV, preferred to have it as far behind and away from the driver (me) as possible.
It would be easy to extend the "tow caddy" tongue but it seems to be far enough as is.
