CH4Ohio
They also make a regular tandem-axle semi-trailer version of this, which would obviously take less brain power to reverse into tight quarters, but wouldn't be stable when loaded with a few thousand pounds of firewood and not attached to a tractor. Likewise, when moving dirt or mulch, I can disconnect this wagon from the tractor, and use my FEL to load the wagon, with zero concern for it tipping on me.
Oh, and for those talking about using your tractor's drawbar to move wagons... good luck doing that with this rig! When backing an articulated wagon like this, you really need the hitch to be far aft of the rear axle of the tractor, in order to get sufficient swing on the drawbar to steer the thing.
Obviously, there's two steering reversals happening, when you have articulated steering on a wagon, versus a regular semi-trailer. Most people think it's impossible to back these trailers into any tight space, but you can see I do it every 2 - 3 weeks thru or entire heating season, without too much trouble. It does take practice, but it's do-able with the same finesse and accuracy of a regular trailer, by the time you've done it a few hundred times.![]()
I've seen dump trailers at Rural King in the $3-4 thousand range. But theirs have the tandem-axle setup that you mention. Would be much easier to back up -- as you mention. But I like the setup on yours with the wheels spread apart and steerable on front because of the stability. Yours is setup like a farm wagon as opposed to a trailer.
