How to fix uneven cut
/ How to fix uneven cut #1
yooperdave
Marinette, WI
Tool Cat 5600, LS XJ2025H, Branson 4215HC
I brought my 6 year old 54" Toro ZTR mower in late last Fall to get the blades sharpened, tune-up and a wash. I was moving 75 miles away and wanted to get the mower as maintained as possible before relocating. Starting the Spring mowing season, it was more than apparent that the mower was not cutting evenly. The grass was growing like crazy as we received more than 8" of rain beyond the average for April. I cut the lawn to at least get the grass under control. What suggestions do you have to level out the cut? TIA
Yooper Dave
/ How to fix uneven cut #2
Well, the last time I "fixed" a mower for this... The owner had one rear tire inflated to 40psi!!!! The other was the correct 8psi. Once I deflated the tire, it was fine.
It could also be an issue in the linkage that the deck is suspended from.
But, if it happened all of a sudden, while not in use, I'd be looking for a flat or over-inflated tire
/ How to fix uneven cut #3
Or a loose blade bolt.
/ How to fix uneven cut #4
It helps to have a good blade height gauge.
/ How to fix uneven cut #5
I'd measure the DECK height side-to-side. And also measure the BLADE-to-GROUND height side-to-side. If your deck is bent or tweaked, this should show it.
As mentioned above, first be sure all tires are at the same pressure.
Are any blades bent?
If all of that seems OK, then you'll look at the linkages that the deck hangs from. I'd be surprised if TORO doesn't have a pretty simple leveling system -- need to check the manual online. I have a 60" Cub Cadet where you adjust hangers on a threaded-rod -- sorta like a turnbuckle assembly. Your hardware will determine how to proceed.
Also wouldn't be surprised if one side is more adjustable than the other. Check it out. Often designed with more flexible / adjustable hangers on one side.
/ How to fix uneven cut #7
All good suggestions. The JD gauge is cheap and easy to use (Except for David? :LOL: ). That pattern is so bad, I would pull the blades and make sure one of them isn't loose or badly bent. If none of this helps,you may have to consider a bent spindle, although that is almost impossible.
/ How to fix uneven cut #8
I can't even figure out how to use that guage!
How about just a tape measure?
David from jax
The gauge tool looks really handy to me! Problem is, I'd never be able to find it when needed.
/ How to fix uneven cut #10
I can't find a tape measure when I need one!
David from jax
Neighbor asked if he could use my TIG welder to build a T-top for his boat.
First day, we can't find a tape measure, so he walks down to his house and gets one.
He left it at my house at end of day.
Day two, we can't find a tape measure, so he walks down to his and gets one.
Day three, we can't find a tape measure, so he walks down to his house and gets one.
Day four, we can't find a tape measure, so he walks down to his house and gets one.
Day five, we started tripping over tape measures like crazy!
The next day he brought me a neon green tape measure because he figured it could be seen anywhere!
I probably only had a dozen or so tape measures around here on day one!
David from jax
/ How to fix uneven cut #11
It's possible that the deck is mounted unevenly to the mower. Are the hangar bolts bound up or is a stick keeping them from holding the deck evenly?
Also possible that one of the blades is bent or the deck itself could be bent.
I bent my deck last year. Although there are a bunch of videos on YT, the one that helped me was the one by Individualized Repair. It helped to gradually beat it back to shape almost like an auto body repair instead of trying to beat it back straight with a few heavy whacks.
Patience also helpful. I had to measure and re-measure several times.
/ How to fix uneven cut #12
Did you put the blades on upside-down?
