John Deere 650 Hydraulic Filter
/ John Deere 650 Hydraulic Filter #1
BeeJay42
MF-285
I have a 1983 650 which works great. I changed all filters/fluids after I purchased it except for the hydraulic filter. I have the cut sheet that shows a sleeve type filter RE27284. When I look that up on all websites I can find included John Deere official site it gives me a screw on filter. The cut sheet show the screw on filter with a different part number. When I use that part number I get the same results as when I use the sleeve part number.
I have attempted to look up the model number - 0650S006640CH but other than finding the year, no other website recognizes this.
How do I find the correct sleeve filter for the hydraulics? YouTube shows how to change it, and some are metal mesh filters which I could just clean I guess, but other show a cloth filter.
Any advice would be greatly apricated.
/ John Deere 650 Hydraulic Filter #2
8spd. 2cyl. HS-4150 Filter screen element Yanmar. They use it on several models. The Ym240 JD. Same as my YM2000 Yanmar Element
Are you talking about a 650 tractor? It shows CH14816 filter in the Trans.Usually you just pull it out and clean it .They cost about $100.
jdparts.deere.com and look under trans case for parts number.
John Deere page said it will not fit my model - appears there are 8 different models of the 650 and I'm unable to confirm mine as nothing shows the model number is correct.
These have a plate attached to one end. Does not match what mine is. Appears there are eight different versions of the 650 and three or four of them have completely different layout.
/ John Deere 650 Hydraulic Filter #5
Is it a power shift Trans. or gear shifted they all bolt up. Only a couple options org. Available. PS. will have a spin on also.
