No dipstick?
/ No dipstick? #21
I think we've reached the point where automatic transmissions are no more likely to leak than manuals. When was the last time you saw a dipstick on a manual transmission?
For me at least the dipstick is as much about fluid condition as level.
I pay close attention to the color of oil when checking it- too dark and I change it, life remaining be darned.
Manual transmissions, like drive axles and gearboxes, once they’re broken in tend to be easy on oil. Big concern is really moisture building up.
I service my automatic trans and T case on my truck twice as frequently as I do the axles for that reason. (25k trans/T case, 50k on driveline)
There’s also the bit of trying to add oil to an auto trans that doesn’t have a dipstick, real pain in the behind.
I drive moderate, not a granny but not a lead foot. My trans likes to operate at 120-150 usually but in the summer she’ll warm up to 180 on the hills. Warm enough that oil breakdown will occur. I’ve heard of a lot of transmissions that will run up to 210 or so.
Granted I work on tractors and not cars, but then again I never heard of somebody who never changed the gear oil in a manual box and lost it at 150k (Not that I would try it!) It will kill an auto to do that though.
/ No dipstick? #22
just started reading this thread but...
Forcing us back to doing it like some motorcycles. Totally inconvenient for owners who do their own maintenance.
IMO rates right up there with Tesla when they removed the turn signal stalk - actually that is the worst stupid thing I have seen, once it really cost them sales they put them back in the following years, Maybe enough owner complaints will get Ford and RAM to put them back. A bad sensor can also give bad info to the computer. What about kids on a trip driving a vehicle that uses oil no way to know exactly how much to add.
^^^ Prone to snapping off at the red line ^^^
/ No dipstick?
I had a dipstick snap off at the red line on a 2011 Chrysler 300c. I think the plastic swelled a little over time. I actually drilled into the remaining plastic with a small bit and yanked it out.
/ No dipstick? #24
I had the reverse issue- dipstick was fine on my Silverado, but the tube rusted out and broke in half!
/ No dipstick? #26
We had a Lincoln that had the same transmission as the her Fusion. Since it was always at the proper level when I checked, when it came time to change I would just drain what I could into a measuring container. Then replace the exact amount I drained out. I did this when I changed oil in the motor. Over about 5 oil changes I figured that I had got most of the transmission fluid changed. It aint like it used to be on vehicle maintenance.
/ No dipstick? #27
Surprised there is a drain and level plug accessible for changing oil. I don’t remember which vehicle it was but it was a “sealed” trans with no fill port either.
My 2008 M-B W211 is like that.
IE.
No dipstick or level checking plug either, but instead it's filled through the drain plug opening on the bottom!
I have done it couple of times myself and it's not really a big deal, but you need to be "a handyman" with some tools and will need the instructions for your car & proper manual oil pump with adapter.
The design certainly discourages DIY service...
My adapter:
/ No dipstick? #28
/ No dipstick? #29
Newer? My 1976 Kawasaki KZ900 used a sight glass. No dipstick. I don't know that they were the first but all the 900's and KZ1000's used a sight glass. The Z1 was the first of the 900's. Sight glass is right above the brake pedal on this Z1b.
Yep my 1978 z1000 and also current 40 years newer 2018 z900RS both came with sight glasses.
/ No dipstick? #30
IE.
My adapter:
VW did that on the newer style automatic bugs as well. Sucks having to run the engine up to a certain temp and then get under the car- engine running to verify oil level.
Actually Surprised VW didn't want the car in gear when checking...
/ No dipstick? #31
What is it with no dipsticks these days? Do they not trust people to look at them? I changed the transmission fluid in my daughter’s car and there is a fill plug on top that access to is tough. It’s a 2016 Ford Fusion, 150,000 miles. Then there is a plug on the side you remove and fill it until it runs out. Then drive it to warm it up and remove the plug and check it again. A dipstick would be much easier.
Guess what? Some of the newest vehicles don't have a dipstick for checking engine oil either. There is a setting on the dash so you can see the oil level on your in-dash display. Saw a You-Tube video where someone checked the accuracy of the in-dash display by draining a quart of oil out of the engine. The in-dash display didn't change.
/ No dipstick? #33
I meant to post this here, but site went wonky and when I came back, I put it in the wrong thread it looks like!
2002 Volvo S60 had a dipstick, but it was only about 2" long and had a clip you had to push out of the way to be able to release it to pull out ... It was down at the bottom up near the radiator and you had to remove the air intake to filter just to snake your hand down into get it . . .
2018 RAM 1500 w5.7 and 8 speed with single exhaust, Y pipe crosses just under the drain plug ... Then follows along under the side so you can't remove the pan bolts . . . Filter is integral with the plastic pan, have to replace the pan to change the filter! Plug in side to fill ... What a stupid design!
/ No dipstick? #34
Pretty much all cars and trucks have this now. It's a bit of a pain, but you don't change trans fluid that often.
I think it's so they don't have to figure out where to run the trans dipstick. Engine bays are tight these days. Also it reduces BOM cost by a few dollars to leave the dipstick off. Few people change the trans fluid. Most dealers will tell you it's "sealed for life". Even fewer will do it themselves. So I don't think it's to discourage home mechanics.
/ No dipstick? #35
The fill plug on the Fusion transmission is on top but the access is terrible, buried under the air intake hose, wiring and an AC hard line almost on top of it. It took a couple of minutes to get it out but 10 minutes to get it back in.
Have one at my repair business now that requires removal of the battery and tray for access to the fill plug. Like most of the transmissions without dipsticks, it requires overfilling and draining to the proper level upon reaching the exact correct temperature read on the scan tool or with a thermal imaging camera. Sounds complicated, not really. Just expensive to have the proper equipment and service information. They are really forcing out the casual DIY repair guys.
/ No dipstick? #36
Sealed for life means the life of the warranty.
/ No dipstick? #38
correct me, but on some automatics, there is no drain plug and changes involve vacuum removal for fluid change from fill plug. i once attempted to change auto fluid on an older import truck for a friend...i could not find the drain plug.
what kind of idiocy is that?
/ No dipstick? #39
That's a level of dumbing down I won't participate in.
/ No dipstick? #40
What about checking to ensure you haven't cooked it? One thing that they finally started adding is a transmission temperature gauge. Aside from being able to monitor, it made me realize how important a cooler is. My Colorado with cooler runs about 95 pulling a 3000 lb trailer. The GMs my company bought didn't have coolers, and ran around 190° in everyday driving. They also overheated quicker when working them, on more than one occasion I had to stop to let the fluid cool when pushing through snow.
Displays have come a long way. I also like the transmission temp display. I have the dash display configured on my GMCs to show it constantly. Along with the trailer brake controller output when towing. The TPMS display is great as well, for both vehicle and the trailer tires.
