A question for the big rig drivers on here
/ A question for the big rig drivers on here #1
alexpops
NSB, FL
LS XR4150, CAT 303.5CR, Kubota ZD331
I know there are several on this site.
I need a big sailboat transported cross country, CA to FL. 44'x12.5'xprobably12' weighs about 28-30k and has a mast 60' that will also need to come over. I assume this requires a lowboy or specialty hydraulic split rig trailer.
What is a fair price I should expect, and will the height require pilot cars? Height may be off, been a long time since she's been on the hard. I expect the width may also cause some permit issues.
What would trailer rental cost me if I need to leave the boat on it until I can get a shop built?
Any insights, warnings, things to watch for will be appreciated.
Not sure if this is the right spot for this ... mods feel free to move if necessary.
Also, while the question isn't about a tractor, a tractor WILL be used to help in the shop build.
/ A question for the big rig drivers on here #2
Not a driver but do know for sure you'll be an oversized load on width. The height will be awful close to needing pilot cars. There are a few over the road drivers on here. May take a day or two to chime in.
/ A question for the big rig drivers on here #4
It’s going to be a substantial amount. I’d be seriously surprised if it’s any cheaper than $10 a mile. Is sailing the boat there out of the question?
/ A question for the big rig drivers on here #5
I don't haul much, just a dry van, so anything I say about it is going to be a guess. Short of sailing the boat thru the Panama Canal, which in itself won't be cheap (but a lot more fun!) I would seriously consider putting the boat up for sale and buying another one when I got the shop built. California would seem to be the better market for the boat, due to how much things cost out there, and Florida would be a better place to buy a similar boat. Plus you would probably have over $25k and maybe even up to $35k to add to the selling price to buy a new boat in Florida.
Somethings aren't for sale, so if you got to do it, you're going to need options.
There are dedicated boat haulers out there, wiggle googles chains and start price checking.
You're going to need a serious trailer. Most of the ones I see in passing may not have the ability to handle that big a boat that high off the roadway, unless it happens to have a removable keel. (doubtful, although I knew a guy who cut his keel off since the boat had worms in the bottom of it anyway. That made hauling it lower a lot easier.
I can't imagine having to figure out a route from one side of this country to the other while dealing with over width, over height and over length (you did say the mask was 60'?) It will probably have to be laid down across the boat due to the over width, but that means you got to have supports to handle the cantilever. I am wondering if buying, renting or borrowing a long trailer (or what I call a pole trailer where the rear wheels are way back there and all is going up front is a piece of pipe, hooked to a pickup to haul the mask. A hotshot with a 53 or 45 foot trailer might haul the mast cheaper than you could add it to the trailer with the boat. If you don't mind buying a long trailer, you might do well to put it behind your pickup and make the drive with it yourself. Sell said trailer when you get done with it. As far as the trailer for the boat, call some of the dedicated boat haulers, but with fuel over $5-6.50 a gallon, that ride isn't going to be cheap.
Make sure that you see the hauler's insurance or talk to their insurance company. You don't want something to happen and you end up with a broken boat. Might also want to double check your boats insurance to make sure it is covered while being transported.
Escorts may have to be hired to cover front and rear, plus how many states will the escorts cover? A lot of times, they are only good to the state line, and you have a bunch of those between you and Florida!
I generally look for ways that "I" can haul stuff, but with this one, I would be stretching it to say it was anywhere near my wheelhouse!
David from jax
/ A question for the big rig drivers on here #6
That's pretty big to ship across many states by truck. Could via railroad work out? Maybe a sailboat broker has experience with that.
But I like the Panama Canal option!
/ A question for the big rig drivers on here #8
I too am just a dry van driver, my understanding is anything over 8'6" wide is oversized, and most states require an escort/pilot if over 10'6" wide ...
I know there are a few specialized boat/yacht haulers out Florida ... That's who I'd call for a quote ... Your boat is probably gonna be in the 15'+ high range once they get a trailer under it, so will require special routing around some low bridges ... "It's only money" comes to mind!
I'd be curious what the quote comes out to be, including what the escort/pilot cost ...
/ A question for the big rig drivers on here #9
Thanks for the responses so far. Keep them coming. I'm also looking at the possibility of multi-modal (via ship to Port Everglades or JAX then at least a shorter road run on 95 to NSB).
Of course ... this reminds me of the line from the Hee Haw song ... "if it weren't for bad luck I'd have no luck at all". Naturally, I get hit with a request by the marina to move the boat at a time when fuel prices are spiking & I can't get to CA to find local storage spaces where they have the equipment to get her out of the water & on the hard.
/ A question for the big rig drivers on here #11
Out of curiosity, what convinced you to buy a boat so far away, without figuring this all out before you actually agreed to purchase it ?
I've owned the boat for close to 30 years. Used to sail her regularly all the time. Bought a place in FL about 10 years ago with the idea that wife & I would sail her here once I retired. Wife got sick & I have little time to get to CA since she needs someone with her 24/7. So, marina wants me to move so they can bring in higher berth rental. Current plan is to store on the hard close to me & refit the boat slowly so when wife is gone I can still sail away.
If this was simply a coastal cruiser I'd say the hell with it & sell or donate ... but this is a true blue water boat & if I sell, I'll never get back into anything comparable.
/ A question for the big rig drivers on here #13
Sorry to hear about your Wife!
With the boat as large as it is, I had a feeling selling it wasn't in the cards, with the option of buying one locally.
This would really tax my inner mind, but do you have any sailing friends (GOOD ONES!!!) that need a vacation? A "most expenses" paid, one way ticket to the "Mouse's House" might be one way to get it here. I would be a nervous mess the whole time it was underway, so probably wouldn't work for me!
Have you considered having someone do the looking for you to move the boat to a different, cheaper location? Having the ability to pull a boat that size out of the water will take a good size travellift.
Last, and probably not a good one, have a live in nurse or nurses care for your Wife for a short period while you go move the boat to higher ground? My thoughts moving the boat would be better paid for than the nurses, but an option.
There are owner operators that do this type of work regularly, who have support staff at home for the permits, and enough vehicles sitting around to make escort cars. The problem is, finding one of those who is trustworthy, a good driver, has a handle on permit purchases, has the proper type of trailer and is willing to go to California.
You haven't mentioned where in California the boat is currently stored. There is a lot of difference in crossing the USA from San Francisco to Florida compared to crossing from San Diego. The mountains, twisting roads, SNOW in the passes, etc will all affect your rates. Paying for the less number of permits, as in the least number of states you have to travel thru might also help. I doubt it would offset sailing the boat from northern to southern would offset the rates, but it sure seems like a better route, especially depending on the time of year that this all falls together.
David from jax
/ A question for the big rig drivers on here #14
Not knowing much about sail boats, the mast can be removed or replaced, right? So, the width, length, and even the hull height can be done, as long as the mast is removed. No, it wont be cheap.
You also will need a crane to sling unload at the destination.
Greencove Springs has several specialists, and one of the space shuttle fuel tanks is still sitting there, after it was barged to the ship yard.
There is also a contract boat mover in Pomona Park, Cool Breeze Transport.
Regardless, you going to need to make some phone calls, give specific measurements, and get prices.
/ A question for the big rig drivers on here #15
Boats are pure money pits...
/ A question for the big rig drivers on here #16
On height, its really going to be a measurement from the road to the highest point; so, 12.5 ft, plus the trailer. Its going to very close to the 13'6", and 100% that will require a specialized trailer. The width, will require escort vehicles. 12 ft wide, but again, the trailer set up, to minimize height is key.
The mast, I dont know if there is a way to carry that on the same trailer? Is it a monolithic pole, or can it be separated into sections? Getting it down to 45 ft (or 53 ft), simplifies things.
David from jax
Thanks for the thoughts on my wife, David. You & I seem to be coming to the same conclusions ... I am currently having legwork done by both me & a friend to find alternate storage in CA. The boat is currently in Sausalito, which is a potential problem for a Semi, but could relatively easily be moved to Richmond or (with some additional planning & crew) South to SD/LB/LA like you said. I may wind up having to do a live in caregiver for a month or so to arrange temp storage/logistics/etc., problem is no insurance for what she needs ... apparently bathing/dressing/eating aren't considered medical necessities & don't get covered by health insurance ... need long term care insurance for that, which neither of us ever had.
CA offers a non-commercial Class A that I considered briefly in conjunction with getting a 38K GN trailer from Kaufman, but the combined weight would push over my 3500's limit & not sure that other State's would recognize a "non-CDL" CDL ... especially now. I also assume that no one would rent me a semi based on a CA RV Class A (essentially). The permit issues sort of sealed the deal that I need a professional that knows the ins & outs of the various states. I also don't have the time to do a driver's school for a regular CDL which is probably only needed for this trip & would potentially cause me issues if I did get in trouble with my normal driving habits ... lol.
Maybe your semi's wouldn't have an issue crossing the Grapevine to hook into 10 with that type of load, but I know every time I've towed anything of weight I've been a lot more comfortable ducking out at Bakersfield to get over to 40 especially for the downhill side. Same states, just avoids any real grades except through the Tehachapi's & around Flagstaff, which has always seemed easier to me. With a load this big, 10 may be the only real option since I doubt it would be legal on the TX & MS State Routes I use between interstates & anyone with half a mind intact would want to avoid Dallas traffic (from my limited experience). I purposely began avoiding 10 during the open border period since I had visions of me plowing through a crowd at night that wasn't visible. The deer through stretches of West TX were bad enough.
I have 1 friend I would trust (sort of) to skipper a crew & sail her across, but his wife got into horses so they split their time between AZ and WA & I don't think he'd be keen on leaving her alone for the 40-60 day trip (assuming canal transit scheduling isn't delayed by more profitable vessels in the locks -- sailboats and cruisers are very low on the food chain in the canal, & regularly get bumped).
So yeah ... a temporary live-in service may be my only real option to get something done quicker at less than Elon Musk type pricing.
Most boat haulers will wrap the mast & either strap it to the deck in a cradle or have a special rack on the trailer. worst comes to worst, I could fab up a 40ft GN carhauler with a rack than would leave me with minimal rear overhang. In terms of height, if necessary, I could drop the keel & strap that in separately under the boat's overhangs but that will make weight adjustment a bear ... keel is 12,600 of lead wrapped in fiberglass. Also, opens a whole new can of worms in terms of reassembly since keels are not meant to be dropped normally.
The mast is an extruded aluminum oval tube for its entire length.
/ A question for the big rig drivers on here #19
I can put you in touch with my cousin if you would like. Her and her husband are veterans of the sea. They have sailed boats from the Caribbean to the Mediterranean for people who wanted to vacation there in their own boats. They have taken boats through the Panama. I am not certain where they are now. However about 2 years ago they sailed to Australia. (Her husband is an Aussie) They might be an option to sail it. I don't know anything about cost but I know you are going to spend a huge amount to have it hauled. So it might be a better option for you and it might not. I just checked and they are in Hawaii currently but two weeks ago they were in the Bahamas.
/ A question for the big rig drivers on here #20
I know it's $300 to pick up and drop off my little TYM T224 should it need to go to the dealer. I'd imagine a 30,000lb big sailboat would be 20-30x that.
