Towable Backhoe
/ Towable Backhoe #1
Willis53
Kubota BX2380
Hey Guys,
I have a question but don't throw rocks at me, lol I have about 9 acres of land and I have a need for a small mini excavator. I can't afford the price for one of these so I have come across what they call a towable Backhoe. Everything I need to do is pretty much light weight, but I am thinking about buying one of these instead of renting the Mini ex every time I need it. I have done a lot of research on these units and and narrowed my search down to two brands. I know that Harbor Freight and Northern Tool sell them but the two I have found are built with thicker material and appear to would to last longer. Does ANYONE have any experience with a towable Backhoe? I look forward to the responses.
Willis
/ Towable Backhoe #2
In my opinion I’d ditch this idea and buy a Chinese mini ex, but do your research. I bought a higher end one (Kymron) and have 130hrs. on it, so far great little machine. I just don’t see the towable HF type as being too useful when you can spend a little more and get a more useful machine, IF you get one of the better alternatives.
Just my opinion, only worth what you paid.
Mike
/ Towable Backhoe #4
Hey Guys,
Willis
My neighbors have a DR tow behind which has done a lot of work for them. Don't expect to rip stumps out of the ground, but for light work they say that it beats a shovel.
/ Towable Backhoe #5
Mike,
Thanks for your honest opinion, I will look at the Chinese mini ex.
You’re welcome,
I forgot to mention if you scroll through the forums down to excavators there are a few threads on different Chinese minis others on this forum have bought.
Mike
/ Towable Backhoe #6
Hey Guys,
Willis
I’ve seen guys who’ve bought 3 point backhoes, or hoes off junked TLBs, put them on a frame with a good stout axle, and driven them with a PTO pump. Boom, a really stout towable backhoe and it could cost you a bit less if you do it right.
/ Towable Backhoe #7
Yes- also,
If the OP has mechanic skills, keep an eye out for an older JD, Ford, or CASE, tractor with a factory backhoe.
Sometimes can be found and bought for similar money to a china mini or HF towable units.
Not as compact and no turntable like the mini's but digging power and reach can be much greater.
If no mechanic skills, the china minis may or may not be easier to keep running with the quality control reports on new units some folks report. In that case a towable has less to go wrong than either a mini or an old backhoe.
/ Towable Backhoe
Yes- also,
SD455dan- I don't have heavy equipment mechanical skills but I feel real good that I could work on and fix the towable backhoe. There is a company out of PA called Liberty that seems to make a good quality unit. I will keep doing research, and another thing my budget is around $7 grand.
/ Towable Backhoe #9
For 7k you also might find something with a subframe to go on your BX. Depending on what you plan to do with it, that might be a viable option.
Personally, I prefer working with something to working on it.
2017 Scag SCZ72V Cheetah 72in. Zero Turn Commercial Mower (A64194)
2017 Scag SCZ72V...
John Deere 12in Channel Bucket w/ Teeth Excavator Attachment (A64194)
John Deere 12in...
UNUSED 2023 JCB S3246E ELECTRIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
Trench Box (A64553)
Trench Box (A64553)
1997 Duraco Dura Patcher 81DJ Towable Asphalt Patcher (A64194)
1997 Duraco Dura...
2008 GMC 3500 HD 4x4 Ext. Cab 9Ft. Flatbed Truck (A64194)
2008 GMC 3500 HD...
