Mudfarmer
Gold Member
- Joined
- Dec 31, 2009
- Messages
- 402
- Location
- Western Washington
- Tractor
- JD 3005, Kubota B2710, Kubota B2650 (sold the ford 1700 and kubota B7100)
When I bought my B2650 in 2019 I had R1 tires installed to handle the muddy winter conditions on my tree farm. I have no complaints about traction. However, I often have the sense that lateral stability is significantly less than that of my JD 3005 with R4 tires which I use predominantly in the summertime when mud isn't an issue. The Kubota also bounces around more than the JD on uneven ground. Obviously, the JD is heavier than the Kubota, a little shorter, a little wider and has more fluid in the rear tires to boot (R4 holds more than R1) which account for the difference in stability. My question is, does anyone have experience with putting rear spacers on a B2650 (or equivalent frame size)? If so, were there significant improvements with say, 2-inch spacers (4-inch widening)?
Mf
Mf
