Power Trac Parts Cross Reference Thread
/ Power Trac Parts Cross Reference Thread #61
This is a timely discussion for me because measuring made me realize I need to use a different bolt hole height at the rear in order to compensate for substituting 15" laminated wheels for the OEM rear wheels. The OEM have no marking on them, but measure 9 13/16 tall x 3 wide with a 5/8 bolt hole. You can see PT is now using a solid tire.
The front OEMs are approximately 2" taller than the rears and slightly wider.
The 15" laminated wheels I installed on the front are about 3" taller than the OEMs. I ordered them from Precision Country Products on Amazon which is the affiliate of High Grade. The 15" wheels were too wide for the PT yoke so I ordered the wheels with the yoke and then had to remove the paint on the shaft for them to fit inside the PT tubes. For my second order, I just ordered direct from High Grade.
I don't think High Grade has any 4.10 size tires though.
Won't you need to order a run flat with the appropriate rim? I suspect changing the run flat tire on one of these size wheels would be a pain.
edit: this is what the new tire mount is starting to look like. The OEM is too narrow for a 15" tire.
/ Power Trac Parts Cross Reference Thread #62
Newly acquired PT 422.
I have the robins 22hp engine. Does anyone know the oil filter and air filter part #/have a recommendation on any? Thanks in advance
/ Power Trac Parts Cross Reference Thread #63
Welcome to TBN, and to Power-Trac!
Did you check the Power-Trac cross reference thread?
If it isn't there, Jack's Small engine parts can usually cross reference the engine model to specific parts for you.
All the best, Peter
/ Power Trac Parts Cross Reference Thread #64
All the best, Peter
I didn’t see one listed in there. I did see one for the 25HP Robin but not sure if that would also apply to the 22HP
/ Power Trac Parts Cross Reference Thread #65
I'm not a Robbins expert. I would guess that you can get them from Power-Trac, or Terry may tell where else to get them (and the filter model). It is worth the call. Terry and the parts department are an amazing resource.
1-800-THE-YARD
All the best, Peter
/ Power Trac Parts Cross Reference Thread #66
1-800-THE-YARD
All the best, Peter
Oh yeah, Terry is great! He is probably tired of hearing from me at this point lol. I spoke to him this morning and he gave me the napa hydraulic filter number and I asked about Robin filter and he says should be easy to track down online. I’ll look some more and see what I can find
/ Power Trac Parts Cross Reference Thread #67
Try https://jackssmallengines.com/jacks-parts-lookup/part/robin oil
But I suspect you can cross reference the number from Terry to lots of places.
All the best, Peter
/ Power Trac Parts Cross Reference Thread #68
All the best, Peter
I found it and ordered one! Stens 120-634
But sure enough this evening while flipping through the manuals I got from the original owner I purchased from it had all of his maintenance written in the back of it! Looks like he used car quest oil filter 85394 and sometimes the purolator L14476
/ Power Trac Parts Cross Reference Thread #69
What did he tell you the Napa number was for the 425 Model built in 2015. A wix number might be easier to find.
/ Power Trac Parts Cross Reference Thread #70
It’s a napa 1551 filter. It was pretty easy to get. I have a Napa right near my house
/ Power Trac Parts Cross Reference Thread #71
Thanks, if that is the case, these other filters cross over to it, and should work also, the Wix specs seem to be the same.
/ Power Trac Parts Cross Reference Thread #72
2018 TAKEUCHI TL8 SKID STEER (A64279)
2018 TAKEUCHI TL8...
2025 Kubota L2502HST (A64119)
2025 Kubota...
2019 Freightliner 122SD (A62679)
2019 Freightliner...
2008 Ford Expedition SUV (A61574)
2008 Ford...
INTERNATIONAL 490 - 21' DISC HARROW (A63291)
INTERNATIONAL 490...
2014 Honda Accord Sedan (A61574)
2014 Honda Accord...
