Power Trac Parts Cross Reference Thread
/ Power Trac Parts Cross Reference Thread #61
This is a timely discussion for me because measuring made me realize I need to use a different bolt hole height at the rear in order to compensate for substituting 15" laminated wheels for the OEM rear wheels. The OEM have no marking on them, but measure 9 13/16 tall x 3 wide with a 5/8 bolt hole. You can see PT is now using a solid tire.
The front OEMs are approximately 2" taller than the rears and slightly wider.
The 15" laminated wheels I installed on the front are about 3" taller than the OEMs. I ordered them from Precision Country Products on Amazon which is the affiliate of High Grade. The 15" wheels were too wide for the PT yoke so I ordered the wheels with the yoke and then had to remove the paint on the shaft for them to fit inside the PT tubes. For my second order, I just ordered direct from High Grade.
I don't think High Grade has any 4.10 size tires though.
Won't you need to order a run flat with the appropriate rim? I suspect changing the run flat tire on one of these size wheels would be a pain.
edit: this is what the new tire mount is starting to look like. The OEM is too narrow for a 15" tire.
/ Power Trac Parts Cross Reference Thread #62
Newly acquired PT 422.
I have the robins 22hp engine. Does anyone know the oil filter and air filter part #/have a recommendation on any? Thanks in advance
/ Power Trac Parts Cross Reference Thread #63
Welcome to TBN, and to Power-Trac!
Did you check the Power-Trac cross reference thread?
If it isn't there, Jack's Small engine parts can usually cross reference the engine model to specific parts for you.
All the best, Peter
/ Power Trac Parts Cross Reference Thread #64
All the best, Peter
I didn’t see one listed in there. I did see one for the 25HP Robin but not sure if that would also apply to the 22HP
/ Power Trac Parts Cross Reference Thread #65
I'm not a Robbins expert. I would guess that you can get them from Power-Trac, or Terry may tell where else to get them (and the filter model). It is worth the call. Terry and the parts department are an amazing resource.
1-800-THE-YARD
All the best, Peter
/ Power Trac Parts Cross Reference Thread #66
1-800-THE-YARD
All the best, Peter
Oh yeah, Terry is great! He is probably tired of hearing from me at this point lol. I spoke to him this morning and he gave me the napa hydraulic filter number and I asked about Robin filter and he says should be easy to track down online. I’ll look some more and see what I can find
/ Power Trac Parts Cross Reference Thread #67
Try https://jackssmallengines.com/jacks-parts-lookup/part/robin oil
But I suspect you can cross reference the number from Terry to lots of places.
All the best, Peter
/ Power Trac Parts Cross Reference Thread #68
All the best, Peter
I found it and ordered one! Stens 120-634
But sure enough this evening while flipping through the manuals I got from the original owner I purchased from it had all of his maintenance written in the back of it! Looks like he used car quest oil filter 85394 and sometimes the purolator L14476
1987 Timpte Hopper Bottom Trailer w/ Tarp (A64047)
1987 Timpte Hopper...
Four (4) R207782 John Deere Wheel Weights (A63116)
Four (4) R207782...
2018 ALLMAND MP40-8B1 PORTABLE (3) PHASE GENERATOR (A63276)
2018 ALLMAND...
2018 Western Star 4900 Tandem Dump (A62613)
2018 Western Star...
Great Dane Van Trailer (A63118)
Great Dane Van...
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
