eolesen
That treadle pedal is only on the HST models. The geared Kubota's have a notched lever shift for R-N-F.
Thanks for posting! Your visit to the Yanmar shop made my morning.The salesman did say that the yanmar sa425 had been sitting and it was just the battery. But I should note that then we went to hop on the sa325 instead and it wouldn’t shift between high and low ranges. He was able to pop the tractor up on the bucket and get whatever was stuck free and shift after a second of messing around. Then he tried to demo to how you could get off the seat and it would keep running but if you pressed a pedal forward or reverse it would stop the engine … it did not stop the engine and almost ran him over. Finally, he couldn’t find any pricing info cause something was wrong with his computer.
I’m sure he just had an off day so I’m trying to not let it color my perception of the tractors too much, especially since y’all knowledgeable folks are saying so many good things about the yanmars. But the whole thing really felt like a comedy of errors, and they are the only yanmar dealer anywhere close.
I will definitely ask why the new holland has been sitting so long I’m not sure.
I looked just at the smaller Massey GCs. I didn’t see any of the larger size on the lot, but maybe they were tucked in the back.
The treadle (or Disney haha) pedal felt super weird at first but after a few minutes I actually really liked it. Felt easier when going in reverse
Small tractor with tiny tires will disappoint you later on.
Since you are relatively new to tractors feeling tippy and being tippy might be two different things. My Kubota B2601 will crab walk on a side hill while I am mowing way before it will start to lift one of the rear tires. I've gotten off and pushed on the ROPS as hard as I can without lifting a rear tire. In one area I mow I have been able to lift the rear tire and I stay off it with the tractor.Update:
Had the new holland workmaster 25s out at my property today and put about 0.5 hours on it. That little tractor felt absolutely gigantic on my narrow little trails. I definitely don’t think I could go bigger than subcompact until I make my trails at least a foot wider and the turns far less sharp.
I was worried about ground clearance but even on moderately bumpy terrain it felt tippy. I think it’s gonna be awhile before I feel comfortable traversing terrain where I need the ground clearance of something larger. I know fluid filled tires, a counter weight, and just experience will help with that feeling of tipping but the pucker factor was high today even on what I consider my flat gentle trails.
Your glow plugs must not be working. My MF 2003, 451 starts at 0 without assistance. It's a 52 HP tractor with 490hrs when I bought it for $14,000. It came with a MF FEL= fork attachment.All of the 60 HP and smaller Massey Ferguson's for the USA market are made by Iseki, I'm not sure if they all are made in Indonesia like mine, but I consider it a great tractor, although much smaller than I originally wanted, I'm keeping it now!
Both Massey Ferguson and Iseki (a Japanese brand tractor) are owned by AGCO they are sold in the USA as Massey Ferguson.
What model of Massey Ferguson did you look at? The Massey Ferguson 1E.25 is a MUCH Larger tractor than my GC, and a Compact Utility Tractor (CUT) and should have plenty of ground clearance, comparable to all other CUT's
Back about a month ago we had 1°F ... Even with a 1.5 amp BatteryMinder which has temperature compensation plugged in all night, and a extra long glow session, it wouldn't start, I put a propane torch on the oil pan and hooked up a 10 amp battery charger, in 10 minutes it was running! I just installed a block heater, going to test it this morning in a little bit ... https://www.tractorbynet.com/forums/threads/diesels-and-cold-weather.643934/ when I was at my dealer getting the block heater, the dealer told me both he and his mechanic which both have GC's like mine had trouble starting too ...
I too wouldn't discount the Yanmar tractors, unfortunately some salesmen don't know anything but what the literature says, and some don't even know that ... How cold was it out? Could also have been sitting for quite awhile (months?!) since it was last run, so battery wasn't cranking it well ...
The New Holland is made by LS ... I too would question why it has been on the lot for three years? Is it now a demo? A return? Just a model nobody wants?
Another thing you get with Kubota is a fairly well stocked parts department, and access to a warehouse that can get replacement parts quickly, I'd consider it a "Premium" brand, but you get what you pay for in parts availability and knowledgeable service, in a professional setting ... For a new tractor owner the "treadle pedal" (forward and reverse pedals) I'd think would just be natural to get use to, lots of people run them ...
My Massey Ferguson was the first diesel fired hydraulic powered tractor I owned, I got VERY use to the twin side by side pedal, and now prefer that style, my much more recently and little used Kubota has the treadle pedal, I can use it, but it feels awkward to me to not keep my heel on the floor, so ... I just lift the forward pedal by sticking my toe under it and lift, keeping my heel on the floor ... I make it work!
You can see the pedals with the arrows on them, the two side by side pedals above are the brakes ...
Side view ...
Hello Jack, glad you got the chance to try one out.Update:
True that.... Once the pucker factor sets in, all it takes to send you over is an unseen bump or drop of just a few inches.
rScotty
I doubt the rentals would have wheel spacers, but once the size is figured out, they can be added, same with fluid or steel wheel weights, which will increase side to side stability ...
Yes, tractor rollovers are very real, and all to easy to do. Do a search on Google or TBN or any tractor site. I lost a good friend this year and he was experienced by any standard.
If you feel like you are in danger then you probably are. Once the pucker factor sets in, all it takes to send you over is an unseen bump or drop of just a few inches.
Thanks for all the good photos. I agree. ...Those are all excellent ways to increase sidehill stability. Simple, inexpensive, and effective.I added 3" spacers to my SCUT ...
And added windshield washer fluid to the tires ...
Also added 70 Lb steel wheel weights!
Each made a profound difference in adding stability! And traction!
Even though my seat of the pants tip-o- meter was going off, once I got off, I gave it a nudge, then a shove ... It didn't budge, it was still stable!
What would it take to widen the trails? Is it just brush/trees, or would dirt need to be added or subtracted?
These little SCUTS are extremely nimble little tractors!
That photo of you mowing on a slight slope is worth repeating.
rScotty
Just my opinion, but I think you should be looking at bigger tractors. Like Kubota B2601 or bigger, or small L model. Check them out. Get on Facebook Marketplace and search for tractors within 100 miles or so and see what you find. You'll find prices from private sellers much better than dealers. If you're buying newer tractors, it's not that hard to tell if it's been taken care of or not. There are lots of low hour tractors that get sold on Marketplace but you need to watch the listings and be ready to call if you see one you're interested in.
If you're doing your own maintenance, you don't really need a dealer, for the most part. Any tractor shop can pretty much work on any tractor for non-warranty work. All but major repairs you can do yourself.
Seems like you need a large B tractor in the 30 HP range or a small L (using Kubota models for sizing). Rough terrain, working in the woods, probably need a grapple later on, . . . Small tractor with tiny tires will disappoint you later on.
