SouthernSky
You could be right. I did try the diagram Bruce provided to see if that would work. The answer is sort of. I can raise or lower the 3-point and the top bolt will stay in the J-hook, BUT -- I cannot connect the PTO shaft because of the trailer hitch mount under the center of the QH. I may have to grind that mount off to keep the current QH configuration in the diagram. Unless I'm doing something wrong.
Side note - Does anybody truly LIKE their Quick Hitch or was I just hoping for something easier than Pat's??
