TC30 wiring/alternator questions
/ TC30 wiring/alternator questions #1
Thow
New Holland TC30
Afternoon all. Just bought a 2004 TC30 in abused condition - but it started and runs. Able to finish some work I wanted to get down and am now working on getting it back to good condition. Started on the wiring and have the schematic which of course didn't match what had been done to the wiring. After ohming and testing the wires, think I got most back to the way it should. The questions: first, the hot wire going from battery to the 3 fuse box had been cut and connected directly to the fuel solenoid. I identified the correct fuel solenoid wire but is there some other issue this may have been correcting before I change? Second, the alternator had a ground wire going to the stud on the back and the red wire going to the sole tab. The other two went to the two tabs with the connector. Is that correct? I replaced the alternator and researched a little on the wiring hookup and most of the research said the ground is created by being bolted to the engine and that the stud should get the red wire from the battery and the tab the red wire from the ignition. The schematic shows a ground wire to the back. A pic of the back of an alternator properly wired would be great.
Looking forward to this forum and all the feedback to get this back in shape.
/ TC30 wiring/alternator questions #2
It's a 3 wire alternator? If so typically one larger wire is 12v charging circuit,one is 12v keyed and ground. You may also have a tach wire if it doesn't have a mechanical one.
Well, what I've googled says it's a 3 wire but there were four wires hooked up to the old alternator. 3 were probably 16 gauge - including the ground - and the larger wire is probably 10 gauge. As it was setup, I think there was only one "hot" wire to it. Besides the black ground, believe one of the other two smaller ones goes to the instrument panel as some kind of indicator and the other goes to the seat safety switch...
/ TC30 wiring/alternator questions #4
Time to get out the wire disgram
Funny thing is that's why I requested a pic of the back of a functioning one. The wire diagram shows 4 wires to the back but everything I read online points to three and no ground wire. Kind of corn-fusing for a car guy.....
2023 BOBCAT T66 R-SERIES SKID STEER (A62129)
2023 BOBCAT T66...
UNUSED JCT HYD AUGER (A62131)
UNUSED JCT HYD...
Yamaha Golf Cart (A57149)
Yamaha Golf Cart...
Railroad Maintenance Machine (A61570)
Railroad...
2015 John Deere 1775NT Planter (A63109)
2015 John Deere...
2014 John Deere 650K LPG Crawler Tractor Dozer (A61567)
2014 John Deere...
