/ Your last generator Maintenance Run #8,002
No snow predicted for Idaho..again. Only 14” total so far, maybe an inch or 2 remaining. Normal used to be 110” for season.
Bad fire season I predict.
/ Your last generator Maintenance Run #8,003
Today I was giving a final check of some houses I watch. Last house, I checked the generator. RED LIGHT! Something to do with the emergency shutdown switch. Service guy is here now.
So it's You, sending all this snow East and South !
Or, take a page from olde South Park - Blame it on Canada ! (Jetstream is swinging way low recently).
You have to live rural, and have some sense, to realize that snow is like money in the bank... zero is not a good option. Hopefully you can catch up a bit, before end-season.
Rgds, D.
Open Circuit ?
Do Tell, if you hear the final story....
Rgds, D.
/ Your last generator Maintenance Run #8,006
I swapped generators in the power house yesterday installed the L70 Yanmar with 5kw generator.
Made up a 30’ extension to connect generator to power inlet.
Test run later today 🤞
Looking forward to details !
Rgds, D.
/ Your last generator Maintenance Run #8,008
Open Circuit ?
Rgds, D.
Not sure exactly. The electrician that put it in bypassed the emergency shutdown switch. There was an issue previously with the emergency switch. Tech wasn’t 100% sure what the cause was. He got it back online and tested it. Said it was good to go.
Shutdown switch on Unit, or remoted into the house ?
Rgds, D.
/ Your last generator Maintenance Run #8,011
Oh boy, the emergency shutdown switch is a 3 second repair. Reset switch, set generator to off, press enter.
If he bypassed the switch, the jumper probably fell out.
2014 WESTERN STAR 4900 SF (A60736)
2014 WESTERN STAR...
2015 Dodge Journey SXT AWD SUV (A61569)
2015 Dodge Journey...
2022 CAT 289D3 (A60462)
2022 CAT 289D3...
BUYERS PREMIUM & PAYMENT TERMS (A59906)
BUYERS PREMIUM &...
2005 SHOP MADE MANIFOLD TRAILER (A60736)
2005 SHOP MADE...
V.E. ENTERPRISES 500 BBL FRAC TANK (A58214)
V.E. ENTERPRISES...
