/ Your last generator Maintenance Run #8,002
No snow predicted for Idaho..again. Only 14” total so far, maybe an inch or 2 remaining. Normal used to be 110” for season.
Bad fire season I predict.
/ Your last generator Maintenance Run #8,003
Today I was giving a final check of some houses I watch. Last house, I checked the generator. RED LIGHT! Something to do with the emergency shutdown switch. Service guy is here now.
So it's You, sending all this snow East and South !
Or, take a page from olde South Park - Blame it on Canada ! (Jetstream is swinging way low recently).
You have to live rural, and have some sense, to realize that snow is like money in the bank... zero is not a good option. Hopefully you can catch up a bit, before end-season.
Rgds, D.
Open Circuit ?
Do Tell, if you hear the final story....
Rgds, D.
/ Your last generator Maintenance Run #8,006
I swapped generators in the power house yesterday installed the L70 Yanmar with 5kw generator.
Made up a 30’ extension to connect generator to power inlet.
Test run later today 🤞
Looking forward to details !
Rgds, D.
/ Your last generator Maintenance Run #8,008
Open Circuit ?
Rgds, D.
Not sure exactly. The electrician that put it in bypassed the emergency shutdown switch. There was an issue previously with the emergency switch. Tech wasn’t 100% sure what the cause was. He got it back online and tested it. Said it was good to go.
Shutdown switch on Unit, or remoted into the house ?
Rgds, D.
/ Your last generator Maintenance Run #8,011
Oh boy, the emergency shutdown switch is a 3 second repair. Reset switch, set generator to off, press enter.
If he bypassed the switch, the jumper probably fell out.
Generator+AltPwr, big tank, but Big $..... interesting suspension/drive ability....
Rgds, D.
/ Your last generator Maintenance Run #8,013
So this is a solution for a problem that doesn't exist, at least for what....99.5% of us? You're towing around another 2,000lbs so you can tow your trailer...errr sorry...portable generator with you along with it's required fuel to run it. Here's a novel thought...get rid of the extra transfer medium and put the fuel directly into the towing vehicle.
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
500BBL WHEELED FRAC TANK (A60736)
500BBL WHEELED...
INGERSOLL RAND G25 GENERATOR (A58216)
INGERSOLL RAND G25...
2021 FORD RANGER (A60736)
2021 FORD RANGER...
1988 FONTAINE 45' STEP DECK LOADER TRAILER (A60736)
1988 FONTAINE 45'...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
