Shawn T. W.
- Joined
- Jul 14, 2025
- Messages
- 1,925
- Location
- SW Missouri Ozarks
- Tractor
- Massey Ferguson GC 1725 MB - Kubota L5030 - John Deere Z960M
I like numbers and know how much stuff weighs . . . I bought a small 500 KG 1100 Lb hanging scale, sometimes called a crane scale ... Do you have a scale?
While this thread is about tractor attachment weights ... I have a cat who always seems to want to "help" ... One day in the kitchen I had a scale out ... This is Blazer, who has gained about 50% in the last 1.5 years since this was taken, he is curled up in my lap now as I write ...
I tested my new scale with a known weight ... Pretty close!
Then I weighed my newly built ballast box for my SCUT ... I had to take off the bucket as it couldn't lift it otherwise ... 707.0 Lbs.
Then I weighed the factory 48" bucket which I had added a Bxpanded Piranha Tooth Bar too, plus two of @kennyd Bolt On Hooks and a receiver hitch ... 189.0 Lbs
My locally made 42" 4,000 Lb rated pallet forks ... 347.4 Lbs
Bush Hog CRB60 Road Grader, a 60" Land Plane ... 285.8 Lbs
A Bush Hog RTC50G a 48" tiller 355.2 Lbs.
No pictures of my Bush Hog BH115 5' rotary cutter, but it weighs 518.4 Lbs.
My Massey Ferguson BH2720 with factory 12" bucket was kinda tricky to weigh, but I got it! 651.0 Lbs (I had to leave the hoses hooked up so I could move it around to balance the weight!)
