Correctly tie down John Deere 3032e
/ Correctly tie down John Deere 3032e #1
lonesomedove
newark,ohio
ford
I am going to haul my John Deere 3032e tractor, it has a fel and a bh. I believe it weighs under 5000lbs. My question is can i
Use one G70 chain hooked on one side and around the front axle then to the other side. Then the same thing on the back also
a strap on the bh, or separate chains front and rear.
/ Correctly tie down John Deere 3032e #2
One on the front axle and one on the rear axle, plus one for the BH and one for the FEL would be legal, but better off having one for each corner of the tractor ie 4 plus loader and backhoe.
/ Correctly tie down John Deere 3032e #3
Yes perfectly legal and safe to have one chain go from one side to the other, holding the axle in the middle ...
If your talking about using one REALLY long chain for the whole tractor, that "could" be possible, IF you used two binders, as in chain RF of trailer across the axle, add binder to tie into the LF of trailer, then have the excess lay on the floor of the trailer, loop the chain over the rear axle and hook the end of the chain to the RR of the trailer, then come back with a binder to tighten the chain to the LR of the trailer ... Two chains are easier ... I bought a 20' chain with hooks on both ends, and two extra hooks, cut the chain in half, added hooks ...
I prefer 4 chains, and 4 binders for my tractor ...
Yes, you should also put a strap/chain over the loader bucket, and the Backhoe (BH).
You can use straps if you prefer ... Just be aware of the working load limit (WLL) for example if you have a 5000 Lb tractor, you would need at the very minimum of 2, 2500 WLL rated chains/straps if you went completely from one side to the other with it tying into the tractor in the middle ... However if you secure it like I did mine above, you would need 4 chains/straps with a minimum WLL of 1250 Lbs ... Plus the 2 to put one over the loader, and another over the BH, or whatever rear attachment you have ...
/ Correctly tie down John Deere 3032e #4
Unless the rules have changed, if the backhoe can be pinned in the upright position it need not sit on the deck or be tied down for under 10k. That aside, best practice would be to set it on the deck and throw a single chain or a chaff protected strap over the bucket.
/ Correctly tie down John Deere 3032e #5
/ Correctly tie down John Deere 3032e #6
@RayIN posted a good guide.
So for the legal aspect of tying down. Per 393.128.b.1 since you load is under 10K you must have at minimum 1 tie down on the front and the rear of the tractor.
However since you have a loader and a backhoe 393.130 applies. Per 393.130.b.1 you must also fully lower and put a tie down over the loader and a tie down over the backhoe. This does not count as your front and rear tie downs.
I prefer to go above the minimum and when hauling a backhoe I will run chains on the tractor like @Shawn T. W. but go from axle knee to opposite trailer side rather than to the brush guard / weight bracket. This controls the sideways motion and put the tie downs on completely separate parts of the tractor so in a crash you have a lower chance of that part failing. I use 3/8" grade 70 but in your application 5/16" would be much easier to handle and plenty strong. If you have 4 chains on the tractor DOT generally will leave you alone as that is what 393.130 requires.
Over the loader I run a chain between the bucket and the arms.
On the backhoe I run a chain through the bucket linkage as it will control the back and forth better.
There are lots of ways to tie equipment down and everyone has their own idea. But I would view the law (1 tie down on loader, 1 on tractor front, 1 on tractor rear, 1 on backhoe) as the minimum requirement.
/ Correctly tie down John Deere 3032e #7
I'm not aware of any written state requirements for private use, but I try to follow the federal requirements, as I also have a CDL ... We have a thread here of what we see others "getting away with" towing "unsecured" loads ...
A couple more thoughts ... If you have Slow Moving Vehicle triangle on the back of the tractor, you should remove it if you plan on going over 20 mph ...
If you don't have rear landing gear like I do, it's best to put a chock block on the down hill side of the trailer tires, as you will see the rear of the trail will sag as you drive on it, and the front of the trailer will rise, and it can actually lift the rear of your tow vehicle off the ground where your parking brakes are, and the whole thing will take off rolling down hill!
/ Correctly tie down John Deere 3032e #8
Just saw the following posted on another forum, posted yesterday ... They wrote:
The other day I trailered my tractor to my friend’s house five miles away. I used three straps, one over through the clevis on the drawbar, one in the middle over the backhoe frame, and one over the frame at the front where the brush guard mounts.
I will NEVER do that again.
Around a turn, the machine slid across the icy trailer deck. Thank god it didn’t slide right off.
From now on, I’ll be using four separate ties to each corner.
And here are the provided pictures ...
Four separate straps/chains on the tractor would have prevented this ...
/ Correctly tie down John Deere 3032e #9
I prefer 4 point straps for my 7k lbs tractor. Someday I'll invest in chains and binders.
/ Correctly tie down John Deere 3032e #11
As would a half hitch at the clevis. A three point triangle tie down, needs a half hitch at the center point or you can have side movement issues.
/ Correctly tie down John Deere 3032e #12
It is yours you can do whatever you wish! However if you lose your load, and the risk increase with the fewer tie downs you use.
If you contact your insurance carrier, I suspect they will tell you to follow DOT guidelines.
This would mean 4 points of tie down for the tractor (at a 45 degree angle) as well as a tie down for the backhoe and 1 for the loader. Straps or chains is your choice as long as they meet the required WLL (Working Load Limit).
I have seen folks use 1 chain for front and/or rear of the tractor, but to meet DOT, there must be a connect location separate for each side.
/ Correctly tie down John Deere 3032e #13
Equipment under 10,000 pounds can be secured the same as automobiles per the DOT FMCSA rules. That only requires two tiedowns, one tiedown on the front and one on the rear. I agree that four is better and not that hard to do.
/ Correctly tie down John Deere 3032e #14
While it may be legal, I once asked an insurance agent, and his response was several fold citing he would gave to check my policy to give correct info for my situation, but generally he would advise following DOT requirements.
Additional if you use only 1 on front or rear, and one becomes loose for whatever reason, your load becomes free to move forward or rearward as well as side to side. While with 4 points you can reduce that movement even if one becomes loose.
Also it is always a good practice to stop and check tension on tie downs after a few miles of driving. My procedure has always been safety first, second, and third.
/ Correctly tie down John Deere 3032e #15
Lots of commercial car haulers only use a total of two straps over two tires ... Some do all four tires, but it's not required by law for commercial carriers ...
I too choose to err on the side of caution, I own my stuff, and prefer it to follow me where I tow it ...
Has the OP disappeared?
/ Correctly tie down John Deere 3032e #17
That's pretty normal for forums. The OP will ask for advice than go MIA, which is better than getting defensive. Usually because they don't like the feed back.
/ Correctly tie down John Deere 3032e #18
Well ... They logged out 5 minutes after they posted according to the screenshot I took ... Couldn't have gotten much "feedback" ...
/ Correctly tie down John Deere 3032e #19
My little BX 25 has a tie down point on all four corners. I made up 4 individual chains for each corner to match the tie points on the equipment trailer. Enough slack to use ratchet chain tighteners. Those points are tailored by welded on D-rings, so all matches the US DOT requirements which WA state uses/enforces.
When tying down I compress the tires some to assure high tension on the chains. Backhoe and FE loader get 2" wide ratchet straps
Years ago, I had a friend that was a retired state trooper that worked truck enforcement for over 10 years. He told us that private haulers and small contractor types were the biggest violators of tie down rules. He had horror stories of wheeled and tracked equipment leaving trailers and even causing trailers to go off road and overturning the truck dragging the trailer.
The life you save may be your own!
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
2004 Sterling Ambulance Truck, VIN # 2FZACFCS24AM53402 (A65563)
2004 Sterling...
2012 Peterbilt 337 G and H 8000 Container Handler Truck (A64194)
2012 Peterbilt 337...
10 ft bed. 14 ft trailer (A61567)
10 ft bed. 14 ft...
E-Z Trail 300-bushel Gravity Wagon (A66408)
E-Z Trail...
New/Unused Wolverine Hydraulic Screening Bucket (A65583)
New/Unused...
