YM226D Reverse Rotating and Running Away
   / YM226D Reverse Rotating and Running Away #1
HFFarms
NW Indiana
John Deere Model A, Yanmar YM226D
Hey all. I managed to snag an old Yanmar YM226D for cheap the other week that was reported to “Have water in the fuel and wont run.” From my understanding, it’s a pretty common issue. All filters have dates from 2017 on them so I assume its been sitting unused for at least 7 years. Its rough, but the foundation is there so I figured at the price point it would be worth it as a project. Im pretty sure its an old landscape or golf course tractor given the turf tires and rough state of things. Hour meter broke at some point so zero clue on the real hours, but the condition of the loader tells me it was rode hard and put away wet.
Sure enough I drained 4 gallons from the tank, and only 1 gallon of it was diesel. Someone tried to run it, thus they pumped this fuel flavored water through the injection system. The injection pump rack and gears were seized and the internals were nasty. I cleaned everything, polished the plungers and bores, and reassembled with fresh diesel exactly as verified per factory manual. As of right now there is no fuel control. Regardless of rack position the pump is 100% full fuel and I am beginning to think someone was in it before me and it wasn’t assembled as it should. I didn’t touch the metering screws, or ‘Barrel adjust screws’ as the manual puts it, and without a flow test workbench, there isn’t anything I can do about that, so it looks like its time for a new IP and injectors. Am I missing something else here? The governor checks out based on inspection, but manually cycling the rack nets zero change in pump fueling volume. Two of 3 injectors literally pulled out by hand after removing the retainers, and the third just with channel locks, and none had the crush disc under them, so further telltale signs someone has been in there previously. The lack of any fuel on the return side of the injectors when priming and throughout the starting process tells me they aren't functioning properly either.
Regardless, I got it on and primmed the system to flush the injectors. In the process of spinning over the engine with the decompression off I discovered substantial amounts of black fuel/oil mix coming out of the exhaust ports with each cycle. I did get the engine fired, but it took a heat gun at 1500F in the intake for it to catch (65F ambient temps), and it smoked like a banshee while still spitting out oil and gunk from the exhaust ports.
The other issue; While initially turning over I let go of the starter and the engine tried to catch briefly, but stalled near TDC during a compression stroke and kicked back which was apparently enough to spin it backward with the force necessary to start it in reverse rotation. The full fuel situation brought it up in RPM fast before it then ran away on me. I assume it was eating this oil mix. Very unexpected to say the least and my typical “starve the intake” response wasn’t an option, for obvious reasons. Decompression rack saved the day. Throughout the troubleshooting process this attempted reverse running has happened 3 times now along with numerous kickbacks that didn't result in a start. I have never had a non-2-stroke kickback and try to start in reverse rotation. Is this a sign of a well worn engine or possible a sign of way out of sync timing? Checking the service manual, setting timing for the engine is very…..rudimentary….to say the least.
I cant seem to diagnose where the oil is coming from either. Could be bad rings, worn cylinder walls, worn out valve guides/seats, etc. Crank case breather was disconnected and engine was given ambient pressure so I know it isn’t a blocked breather. The fact that its pulling oil like that though cant be good. With no-start/hard starts with temps at 65-70F without a heat gun, excessive smoke, major oil consumption, and the desire to run away via its own oil, is it safe to assume the engine is merely a core and ready for a complete in-frame of both the bottom and top ends? There are a couple of suppliers where pretty much everything can be sourced for not that much money. Only thing I haven’t found though is a camshaft. Is an engine that is functioning in the above manner(s) worth doing this work to or would it be more advisable to source a different replacement engine? I guess, other than doing a full sleeve/piston, bearing, gasket, fuel system overhaul and verifying the crank is still within spec, is there anything else that needs to be looked at/planned for? And prior to purchase of parts, is/are there specific things to inspect to ensure overhaul is worthy or would be a waste of time and relegate this particular block to a boat anchor? Curious what you guys think given that this engine (3T75HA) is prevalent across the JD lineup of compacts as well.
As far as suppliers, is there a preferred one? I see Southern Farm Equipment, Allstate AG Parts, Brand M Parts, and Yesterday’s Tractors. Parts selections seem to vary between.
For your entertainment, the very first start which turned into a backward rotation run-away event I actually caught on camera. Not sure why I hit record, but I did, and you can hear it hit full fuel, and then suddenly begin its best impersonation of a an ‘ole screaming Jimmy Detroit. Let me tell ya, hearing RPMs like that from a little 3 cylinder while standing over/alongside it gets the blood pumping fast, especially as you reach over to try and get it shut down.
   / YM226D Reverse Rotating and Running Away #2
You need to check the governor on the fuel pump.
There is a Matt's Workshop video out there.
   / YM226D Reverse Rotating and Running Away #3
There are several suppliers for parts and overhaul kits.
On the YTOG, we have a long list of vendors and parts suppliers on the WIKI > Resource Page for everything vintage Yanmar up to nearly newer Yanmars.
We have parts manuals and some of the service manuals there for free as well.
As this is a YM226D, the YTOG has the YM-1 service manual also.
The YTOG has the largest following of members on the web, it far exceeds FB too.
Knowing the machine is about 40 years give or take, an unknown life, unknown service history and was worked hard, personally I would do both the lower end and upper end overhaul to be on the safe side of saving the machine.
Once the engine is overhauled, these Yanmars will usually outlast your lifetime before the next overhaul if maintained well. Passing the machine down to your kids, they would appreciate all you put into it.
A 4WD model is a piece of gold. Best to keep it. :)
MODEL
GRAY EQUAL
DRIVE
JIS ENG HP
PTO HP
CYL
ENG TYPE
TRANS
YEARS
WEIGHT
Parts Manual
OPS Manual
Service Manual
Special Manual
Wire Schematic
OIL CAPACITY
OIL FILTER
COOLANT CAPACITY
FUEL FILTER
FUEL BOWL
FUEL CAPACITY
AIR FILTER
FAN BELT
HYDRAULIC CAPACITY
HYDRAULIC FILTER
HYDRAULIC RELIEF PRESSURE
HYD PUMP CAPACITY
FRONT AXLE CAPACITY (D)
YM226D​
4WD​
22​
3​
3T75HA​
PSH​
84-89​
1942​
X​
X​
4.0 qts​
124450-35100​
4.3 qts​
124550-55700​
121254-55510​
19L​
124064-12510​
121023-42290 AX33​
15.0 qts​
194464-48310​
2200 psi​
6.18 GPM​
5.2 qts​
121023-77910​
   / YM226D Reverse Rotating and Running Away #4
Battery terminals reversed making it crank backwards ? Injector pump out of phase? I had the same tractor. Great machine. Baled hay with it.
   / YM226D Reverse Rotating and Running Away #7
There is something quite off. That's a lot of unburned fuel, as the exhaust also suggests. When you turn it over slowly by hand is there compression? Does it feel the same for all cylinders? It could be that the timing is off, or that something is broken internally, but as it seems that all of the cylinders are smoking, timing leaps to mind. If someone else tried to run the engine and hydrolocked it, there could be a few things amiss.
I'd agree with @bmaverick that pulling the top and bottom is probably warranted, even if the governor is correctly set.
Nice machine and I hope it works for you.
All the best, Peter
First thing I did and everything checks out. Regardless of rack position, its full fuel, whether working the rack via gov/throttle or manually with a flathead.
MODEL
GRAY EQUAL
DRIVE
JIS ENG HP
PTO HP
CYL
ENG TYPE
TRANS
YEARS
WEIGHT
Parts Manual
OPS Manual
Service Manual
Special Manual
Wire Schematic
OIL CAPACITY
OIL FILTER
COOLANT CAPACITY
FUEL FILTER
FUEL BOWL
FUEL CAPACITY
AIR FILTER
FAN BELT
HYDRAULIC CAPACITY
HYDRAULIC FILTER
HYD PUMP CAPACITY
YM226D​
4WD​
22​
3​
3T75HA​
PSH​
84-89​
1942​
X​
X​
4.0 qts​
124450-35100​
4.3 qts​
124550-55700​
121254-55510​
19L​
124064-12510​
121023-42290 AX33​
15.0 qts​
194464-48310​
2200 psi​
6.18 GPM​
5.2 qts​
121023-77910​
YTOG, beautiful, this is exactly what I was looking for. Ill start digging into things there immediately. Thank you for the direction. Im old school and prefer hard copy manuals, so I have a copy of the original service manual for this tractor. Reprint quality isn't half bad.
All of my research has led to the same conclusion. These little tractors were overbuilt from the start, are ridiculously reliable, and last forever. It will fit right in next to the old '47 JD A.
I believe I would send the injection pump to this guy. Log In
Does he accept pumps that have been "worked on" by non-professionals? Some places don't like to hassle with that, understandably so.
All the best, Peter
This thought crossed my mind as well. With water through the injection system it can be inferred that the PO tried to start it, thus pumped a bunch into the combustion chamber. If they just kept on cranking, it certainly isn't impossible for them to have hydro locked it and caused any amount of significant damage to both the bottom and top ends. The ease of it wanting to start backwards makes me think the timing is way out of sync as it struggles to start normally, but a simple kickback is all it needs to start in reverse. Not to mention the whole reverse starting in a non-2-stroke engine. Another observation is the white smoke from the exhaust ports when cranking but black smoke from the intake once it starts in backward orientation.
   / YM226D Reverse Rotating and Running Away #9
Yep, pump timing must be exact, it's not like timing a gas engine whatsoever.
   / YM226D Reverse Rotating and Running Away #10
   / YM226D Reverse Rotating and Running Away #11
I'd be looking for a good parts tractor. Your going to need quite a few is my guess. All the water pretty much trashed that motor. Golf Course Parked it! And that's just Eng problems. Does it go into gear and Move? Interesting thread already.
2860 (A56857)
2860 (A56857)
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
2014 Ford F-250 4x4 Ext. Cab Pickup Truck (A59230)
2014 Ford F-250...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2012 TOP HAT TRAILER GOOSENECK FLATBED TRAILER (A58214)
2012 TOP HAT...
2023 FORD F-650 SUPER DUTY CAB AND CHASSIS TRUCK (A59823)
2023 FORD F-650...
