Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions?
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #91
I did the same thing 10 years ago. I welded 3 steel straps to the pipe, each about a foot long and drilled a hole at the end of the strap through the plow blade. I can take the pipe off in a few minutes by removing the bolts. Works good in my stone driveway. It should be heavier. And I should weld a plate over the open ends of the pipe because when the blade is angled it collects dirt and stone It angles using the hydraulic hoses that curl the bucket when that is mounted. I plan to add about 200 #'s to it to give more down pressure. I have 400#'s of weights on the 3pt.scrapper blade that I plow backwards with.
That could in fact be the problem. I also have a Bison blade, but it is standard without modification or gauge wheels. It could be those additions that are catching and dragging snow instead of allowing it to be pushed to the side. Here is mine in the reversed position.View attachment 4625042
Lookn' good, but as TMK said, we need to see what it looks like on back of the blade. Got a pic?
My rear blade is about 1,800lbs. Honestly, I think it's too heavy sometimes as it likes to sink in too much.
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #94
Weld some skid plates on the bottom of the pipe. That way you can have to right angle on them to keep it on top of your gravel. The only other way would be to have a larger diameter pipe. Good luck.
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #95
I’m on vacation now. Send me a PM to remind me and I’ll snap a pic when I return after the 29th.
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #96
That’s why if you adjust the top link so the cutting edge points to the rear and positioned like a squeegee it will skim over the gravel. It won’t sink in if the cutting edge is angled correctly.
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #97
Does that angle matter when there's a pipe instead of a cutting edge?
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #98
IDK. I’ve never tried or needed to use a pipe. I think a pipe is a great solution for front plows that can’t be reversed, but reversal of the moldboard is all that’s necessary for a rear blade.
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #99
Also never tried pipe, but know that even with a small light blade used backwards it's not always "gravel proof", depending on the snow and temps.
To put things in perspective, I sometimes use my 9' blade (which is very similar to the OP's) in reversed position to fix the driveway, successfully restoring the crown, when too lazy to switch to the land plane.
If I run it reversed on anything less than a solid base of hardpacked snow/ice it would remove gravel unless I carefully keep it just high enough.
And when there is a good solid frozen base it still doesn't work all that well even with dry fluffy snow. With more wet snow, forget it. Then the snow just piles up in front of it and either starts spilling over the top or begins to lift the blade. Sometimes even letting snow come out at the leading edge of the blade although it's a max angle.
That's all because the snow just won't slide past all the obstacles on the backside of the blade. It almost becomes a snow pusher, except being pulled.
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #100
That has not been my experience. If it’s pulling gravel the blade is too perpendicular. Shorten the top link and let the blade ride over the road at more of an angle.
Edited to add: Yes I also use the blade reversed to spread gravel to re-crown my road. If the blade is nearly perpendicular to the road, it will move gravel, even with the blade reversed. But if it’s angled so that the cutting edge lays flatter behind, it will then act as a squeegee while floating the blade and move snow without moving gravel.
5' ROTARY MOWER (A52706)
5' ROTARY MOWER...
2000 ITASCA SUNCRUISER 37G CLASS A RV (A58214)
2000 ITASCA...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 Ford F-350 4x4 Ext. Cab Rugby HR-520 Mason Dump Truck (A59230)
2012 Ford F-350...
SWITCH HITCH HYDRAULIC HAMMER ATTACHMENT (A60736)
SWITCH HITCH...
2013 Chevrolet Impala Sedan (A59231)
2013 Chevrolet...
