Do you grease the loader settled on the ground or lifted up?
/ Do you grease the loader settled on the ground or lifted up? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Do you grease loader pins with the loader settled to the ground or lifted a bit? One way takes the pressure off the loader and one way doesn't. It must matter in some way because I've taken loaders apart with worn pins but it sure looked like the pins were greased. How do you do it?
Below is an old thread with pictures of a loader pin that didn't get grease from a plugged fitting. I've seen others that apparently were greased but not enough grease and they looked just like these pics.
/ Do you grease the loader settled on the ground or lifted up? #2
/ Do you grease the loader settled on the ground or lifted up? #3
I grease my loader in what ever position it happens to be in. I have replaced most if not all of original zerks since they quit taking grease.
I believe wear is not so much position greased in vs frequency of greasing during use.
/ Do you grease the loader settled on the ground or lifted up? #5
I don't grease,paint,repair,wash or otherwise screw with equipment in a position that can cripple or kill with an accidental bump of control or resulting from leaky hydraulics.
/ Do you grease the loader settled on the ground or lifted up? #6
Few people have ever been injured or killed for being overly careful with equipment. It would be easier on my back to lift it up. Not worth the risk.
/ Do you grease the loader settled on the ground or lifted up? #7
It depends mostly on the ground.
That said when servicing the tractor I use two pieces of thick aluminum angle to block the loader cylinders up.
While in that position I have greased the zerks I can reach.
/ Do you grease the loader settled on the ground or lifted up? #8
Had to think about it for a minute. I grease with everything on the ground and tractor off. Safety sake. Really - if the pins are machined correctly it should make little difference. Up or down.
Down and off is for safety.
HOWEVER - FEL is up with tractor off for ease of getting at several zerks. I block the FEL with a short, heavy chunk of angle iron.
My electric DeWalt grease gun makes this go easier/quicker.
Still have not figured a way to do a complete grease job ( 32 zerks ) without greasing me - along the way.
/ Do you grease the loader settled on the ground or lifted up? #9
I've always greased with bucket on the ground. Only because that's how I leave it when I pull into garage to work on it. Does it really matter in terms of greasing properly?
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
2004 John Deere 310G 4x4 Loader Backhoe (A59228)
2004 John Deere...
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
2019 Toyota Corolla Sedan (A55853)
2019 Toyota...
2008 DRAGON PNEUMATIC TRAILER (A58214)
2008 DRAGON...
2017 John Deere 825i XUV Gas Utility Cart (A59228)
2017 John Deere...
