Snow clearing with PT425
/ Snow clearing with PT425 #2
Thanks for posting the fun videos.
For non-PT tractor owners, that second video really demonstrates the easy turning/maneuverability of PTs.
All the best,
Peter
/ Snow clearing with PT425 #3
Nice! Off topic, but does your camera follow movement? What brand if you don't mind?
All the best,
Peter
Thanks, it can really maneuver in tight places. I'm still getting the hang of it. Coming in close too a vehicle can get a little unnerving.
/ Snow clearing with PT425 #6
And then you get used to the tight maneuvering abilities, and then you get really close to things. I do really like how well the wheels track each other going by objects, but I still look to make sure thatI'm not running a wheel into something.
All the best, Peter
/ Snow clearing with PT425 #7
Some guys put PVC pipe over their bucket edges to protect their asphalt. Think some others have bolted some kind of plastic on theirs similar to what is used on plastic cutting boards.
I’ve seen that but I question how long pvc pipe would hold up. I would opt for steel sch 40 pipe. I like the steel edge since the plow blade has a rubber blade. It’s a good mix.
/ Snow clearing with PT425 #9
All the best,
Peter
Yes, they have a great turning radius. It takes a little bit to get used to the articulation, but 2 point turns are pretty easy on a narrow drive.
/ Snow clearing with PT425 #10
One of the first things I did with my PT425 and my toothed rock bucket is to add an air hose pass through port in the side of my garage. ;)
/ Snow clearing with PT425 #11
2025 48in. Farm Jack (A66734)
2025 48in. Farm...
Metal Rooster Weather Vane (A66738)
Metal Rooster...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
2014 MACK GRANITE(INOPERABLE) (A67714)
2014 MACK...
2012 Ford F-450 4x4 Altec Bucket Truck (A66736)
2012 Ford F-450...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
