SAME Tiger 100, 3 point stuck in up position
/ SAME Tiger 100, 3 point stuck in up position #1
kw_20
Farmall Model A
Hello. We recently got this SAME Tiger 100, we got it running after it's been sitting for a while. Now that it's running the 3 point is stuck up. There's a whining noise coming from the housing. It seems like its just trying to go up. Eventually its gets warm enough and the oil just boils over the fill cap. Moving the levers doesn't change anything (although I can't seem to figure out which one moves the 3 point.) We're stumped on this and can't seem to figure it out, we aren't used to SAME tractors so any advice helps. Thanks
/ SAME Tiger 100, 3 point stuck in up position #4
Page numbers are at the bottom of each of the six pages shown. You'd need to trace the cables down from the control lever.
/ SAME Tiger 100, 3 point stuck in up position #5
Does it have a lever attached to the steering column like this one?
There are no cables
/ SAME Tiger 100, 3 point stuck in up position #8
Potzione is supposed to set the hitch height, the numbers 1 to 12 is the draft control.
If it's like mine (and it probably is) then there are 2 push / pull linkage rods that go back to the 3-point control box.
However, from what you describe, there is a malfunction in the valves.
You say it whines and then starts to bubble?
Other possibility that comes to mind is air being sucked into the hydro pump.
That looks like an 80's tractor, so there are probably 40 year old rubber hoses on it.
You're going to need to get in there and look around.
You could disconnect the hydraulic pressure line and run the oil into a bucket as you start the engine for a minute.
Have you replaced the filters? That could be a start.
/ SAME Tiger 100, 3 point stuck in up position #9
There are no cables
ok, rods or electrics then. Surely it's not electrically controlled is it? I'm just trying to suggest a process of elimination. If the hand slider works, is what it's connected to working at both ends. If it is, then there's a problem with what ever control system it has at the hydraulic end. Looks like a basic, old school tractor so I assumed cables but ....
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Sterling AT (A63689)
2006 GODWIN GHP45KW-RC-45KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
2024 8R 370 Tractor (A63111)
2024 8R 370...
UNVERFERTH 14' FIELD CULTIVATOR (A63291)
UNVERFERTH 14'...
JLG E300AJ (A60462)
JLG E300AJ (A60462)
