Ford kills off its all all-electric F-150
/ Ford kills off its all all-electric F-150 #1
MapleLeafFarmer
Canada
lots including Kubota B's, L's, cat, etc.. over many years
well this doesn't really surprise me but today Ford announced they are killing off their all electric F150.
next to come is a plug in hybrid version that's supposed to be a combo electric-gas job.
so 2 systems / weight / etc... going forward as they concluded all electric is a failed experiment?
that was a pretty quick failed experiment.
/ Ford kills off its all all-electric F-150 #3
I actually drove one once and quite enjoyed it, but I would never purchase an electric. I'm not surprised the Lightning is gone, not am I surprised to see it's replacement is something more sensible.
/ Ford kills off its all all-electric F-150 #4
Plans are to build a F150 similar to the Ram hybrid with an onboard gas generator. Range projected to be 700 miles.
/ Ford kills off its all all-electric F-150 #5
Similiar to the fisker karma built in 2011, the smartest of hybrid designs. Instead of a stupidly complex transmission involving both gas engine and electric motors, take a page out of hte train book and their diesel electrics and have a purely electric drive full of torque and horsepower, powered by a diesel or gasoline engine connected to a generator with a small battery for a buffer.
/ Ford kills off its all all-electric F-150 #6
The trouble with that is you lose a bunch of efficiency between engine output and drive wheels from various forms of power conversion. So to the extent it's running on the engine, it gets worse mileage than if the engine were connected straight through a mechanical transmission like it is in a so-called "parallel hybrid".
I think the lightening failed because it doesn't fit how people use a truck, and where people use trucks. It all comes down to range, access to recharge facilities, and time to recharge. A hybrid solves those problems.
Trains are diesel electric because it's the only (or best) way to build a transmission for that use. Similarly for tugs and cruise ships, diesel electric is about maneuverability. Ships that just go in a straight like for thousands of miles are always engine+shaft+prop. Many don't even have a transmission or clutch, and to reverse you shut down the engine and restart it with opposite rotation. The result is max efficiency while underway, but tug $$ assist is required for docking and maneuvering.
/ Ford kills off its all all-electric F-150 #7
My neighbor has the Ford lightning and he absolutely loves it. I have ridden in it and it's insanely fast. But personally, I am not a fan of electric vehicles whatsoever.
/ Ford kills off its all all-electric F-150 #8
I sense they will be able to be had used dirt cheap in the coming years
/ Ford kills off its all all-electric F-150 #9
So, what will a hybrid cost?
I mean, maybe I'm weird, but $80k plus for a vehicle seems like a luxury that the vast majority cannot afford.
The US consumer is getting buried in debt. The average car payment is ridiculous
/ Ford kills off its all all-electric F-150 #10
I can smell the ozone.
2004 GMC Sierra 3500 Pickup Truck (A55973)
2004 GMC Sierra...
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
2000 Kenworth Tri-Axle Dump Truck (A59230)
2000 Kenworth...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
2019 DITCH WITCH FX25 PORTABLE VACUUM TRAILER (A59823)
2019 DITCH WITCH...
2011 Toro Workman HD Gas Utility Cart (A59228)
2011 Toro Workman...
