New garage time!
/ New garage time!
My wife told me to man up, what sort of example am I setting for my son. Get the washer out, it's not that heavy.
So I did, then got the new washer and dryer in, hooked up, wired up, but not before throwing up a sheet of drywall while everything was out.
2 of 3 heat pumps in place. Dryer is running now and barely notice it.
/ New garage time!
Similiar capacity, different door design. Virtually same footprint. The doors are bigger than they look, it's sort of an optical illusion.
My wife says she doesn't like hte new ones. They don't look "fancy" with the chrome lining and more buttons than the enterprise. But the new ones have a screen on the dial, in addition to the screen to the side.
/ New garage time! #1,643
What was wrong with the original washer/dryer? They look quite new, and same brand as the new ones?
/ New garage time! #1,644
...Get the washer out ...So I did, then got the new washer and dryer in, hooked up, wired up, but not before throwing up a sheet of drywall while everything was out.
How many projects do you get to do where it is just ONE thing?
/ New garage time! #1,645
I had to look at your pics several times to figure out which ones are the new ones. The sheetrock gave it away.
/ New garage time! #1,646
Yeah that was how I hurt my back, but it was getting my Unisaw out of the old basement (up the stairs). It was a 4-man job and I had just 2 of us. Now it comes back and hurts like heck every so often. Learned the hard (and permanent) way. Get a friend or neighbor teenager to help for those things.
I haven't commented here before but have watched the thread from time to time. Impressive setup.
/ New garage time!
The old ones were 3 years old, still in new condition, and perfect in every way. Except the dryer was resistive coil heating. Which causes massive power spikes.
This is my power consumption when using the old dryer:
And my wife has done 8 loads so far today with the new dryer:
/ New garage time!
I called everyone I knew, no one could come. It was going on 3 days with my wife without a washer and she was getting impatient.
/ New garage time! #1,649
/ New garage time! #1,651
How is the heating done differently on the new dryer?
/ New garage time!
It uses heat pump vs the old one was heating elements. Same as the hot water heater i just installed. So it's still electric, just more efficient. I'll be doing a heat pump mini split next, it's already in the shop on a pallet.
/ New garage time! #1,653
I'll be interested to hear how the heat pump dryer works. Most condensing dryers are pretty unsatisfactory compared to a vented dryer with heating element or gas.
/ New garage time!
My wife has not complained, and if you knew my wife, that's quite out of character for her. It does take about 15 minutes longer per cycle, but it doesn't just fluff endlessly, it stops and resorts the clothes in AI Dry mode, that way it doesn't stay a solid lump.
/ New garage time! #1,655
So on a heat pump dryer the heat is rejecting in the dryer, so little to no power used there. The electrical consumption would be primarily on the other end. Curious how the big picture looks. I am thinking of doing that on a remodel.
/ New garage time!
I'm not a heat pump expert, or dryer expert, or heat pump dryer expert. However, from what it appears it's a closed system. Air is heated via heat pump, sent into the drum, hot moist air goes into a compartment in the bottom, it's cooled, water drops out of the air, then that same air is then heated back up. Repeat until dry. It doesn't take air in or put air out, it's only output is water.
/ New garage time! #1,657
I've used the bread trick. Another approach is to install a full port ball valve. Get everything ready, install the valve in the open position and stuff a piece of towel back in the pipe. I used a piece of mechanics wire with a hook to retrieve the rag after sweating the joint. For piping after the valve, just close the valve and no water to deal with.
/ New garage time!
The expansion begins. It'll be fun to route these battery cables from one side to another, without a wall, without unhooking them.
/ New garage time! #1,659
Wow! Talk about spaghetti...
/ New garage time!
Yeah, it's hard when there's 2 battery cables per inverter, and they all have to be equal length to the bus bars.
UNUSED 2023 JCB S3246E ELECTRIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
2022 EZ-GO ELITE...
2007 Mercedes-Benz C230 Sedan (A64557)
2007 Mercedes-Benz...
2016 Nissan Altima Sedan (A64557)
2016 Nissan Altima...
2014 Crossroads RV Elevation T/A 5th Wheel Toy Hauler Travel Trailer (A64557)
2014 Crossroads RV...
