Homemade snowblower chute rotator and deflector
/ Homemade snowblower chute rotator and deflector #1
Harrygoodwrench
Gold Member
Upstate New York
2003 JM 224, LN1714 Kioti
Bought a new 54" SB54 Meteor 3PH snowblower off season last spring. Was thinking about putting a hydraulic or electric chute rotator on it. After getting sticker shock at $1200. for the hydro motor and over $1000. for the electric motor and that didn't address the deflector issue. I decided there must be a reasonable way.
I decided on the winch system. I'm a Harbor Freight IT member and picked up a 2K Badlands winch for $38. Trouble is a winch only pulls in one direction. So it was either hook up a spring return system or make the winch pull both ways.
I removed the cable and redrilled the cable slot with a set screw to center the cable allowing it to be bidirectional pull.
Mounted on a fabricated plate, measure cable and secured both ends to the chute. Winch turns chute effortlessly and at a reasonable speed.
I bought a linear 12V motor on Amazon for $40. and put a bellows boot on it. Hooked up the electrics and as the deflector is a little slow it does the job.
We will see how well my new system works. Last year we got over 200" of snow so I'm hoping for the best.
/ Homemade snowblower chute rotator and deflector #2
What does your Meteor have for shoes ?
The shoes that came my 72 inch Meteor aren’t worth crap. Bought some aftermarket bolt on shoes last year but we didn’t get much snow so didn’t get to use the blower.
Mine came equipped with swivel and tilt.
Looks like you did a nice job rigging yours up hopefully it works out well for you.
/ Homemade snowblower chute rotator and deflector #3
Nice build at a great price!!
In ran into the same problem with my Woods SS74 Blower. When I bought it new, I couldn't afford the extra $1400 for the hydraulic chute rotator, and that didn't even include a deflector.
Instead, I bought this Woodmax kit that included both a rotator & deflector:
It was fairly easy to adapt it to the Woods blower but the price was considerably higher than yours though:
Now, I don't have to leave the cab to make adjustments.
Looks like my MT Martin Meteor SB54 has the same crappy shoes like yours. It will have to wait until spring to address a way to re-engineer this.
/ Homemade snowblower chute rotator and deflector #5
Nice. I have seen that same basic technique done before so you are on solid ground. If you haven't heard of them Surplus Center is a great resource for lots of components and often at good prices. They have new stuff as well as "surplus" but it can be hit and miss sometimes on the more unique stuff. Hydraulics are always expensive, but sometimes needed. Electric stuff seems to make a lot of sense for this application.
What part of Upstate? I grew up in Chautauqua County. We got a lot of snow when I was a kid.
I'm in southern part of Herkimer county. We don't get as much as Chautauqua county but we get the shadow effect from Tug Hill. We had 200+ inches last year and have more than doubled the normal snowfall from November 15th to December 15th at 36.8" so far as per the weather guy.
I usually use my snow pusher but the snowblower is definitely the tool of choice for deep snow.
/ Homemade snowblower chute rotator and deflector #7
Never heard of Herkimer before, had to look it up. Adirondacks foothills, it looks like. Beautiful country. Upstate NY is all quite beautiful country. Too bad it is ruined by NYS government...
Agreed on the blower being best for deep stuff. Living up here now, we tend to get smaller snowfalls that are lighter, but we also do get some heavier dumps. I built a rotary broom for my tractor from an old unit that I refurbed and modified and it works great for the light stuff, but when we get 6" or heavy snow, it is not happy. I've got a wild hair to make a snowblower front end to swap out with the broom, but no place to put it to start, and it would take some serious engineering. Might be a plan for retirement project, perhaps...if I can reorganize and gain some more space.
Here is my build thread if you are curious
/ Homemade snowblower chute rotator and deflector #8
Hey guys, hope you don't mind me jumping in here? I have a SB60 woodmaxx and it really proved itself a few years ago with the 35 inches we got. Spent all day looking behind me cleaning 1600 feet of private road and next road over just on the 300 of entrance. So getting back to my idea, would like to move the 3 point snowblower up to front end blower. Not interested in hydraulic driven was thinking of mimicking the Erskine under tractor drive shaft. One complication would be fabbing my own gearbox for the rear PTO. Then heavy frame going forward with driveshaft converted to male 6 spline. Snowblower hangs off front tractor frame with hydraulic lift.
Figuring the gearing is questionable starting with a 6" diameter then 2 more 2 inch gears and then last gear is 3 inch and last one ends up counter clockwise that's what drives the blower. RPMs are 540 to 1000 is what I want to be able to deliver to front end to blow snow without redlining engine. Of course that 1000 RPMs could be adjusted upon figuring 3/4 throttle. So attaching blower, fabbing gear box mounted on rear and then constructing a frame including a solid shaft with pillow block bearings.
I also bought a atv winch from HF. In watching YouTube videos there's a guy. Titled (adding a winch to my woodmaxx snowblower.) His name is : Unemployed Redneck Hillbilly from South Carolina put a video on there about mounting the winch with bracket and boring out the aluminum cable wheel and mounting on the shaft for toothed gearing from handle. Really slick job so trying to find a lathe or guy with lathe. I do also have a linear actuator for deflector all still in the boxes from a few years ago.
Long post sorry, just want to put it out there so more ideas can flow from all who cares to join in.
/ Homemade snowblower chute rotator and deflector #9
Here's that's link from YouTube.
(INOP) 2004 FORD F-350XL SUPER DUTY FLATBED TRUCK (A59823)
(INOP) 2004 FORD...
203201 (A60429)
203201 (A60429)
2014 BRENNER TANK CRUDE TRAILER (A60736)
2014 BRENNER TANK...
TOYOTA FORKLIFT (INOPERABLE) (A60736)
TOYOTA FORKLIFT...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
2025 AGT Industrial ATK-B1000 2 Post Car Lift (A60463)
2025 AGT...
