Old JD 212 and 214 starter replacement
   / Old JD 212 and 214 starter replacement #1
jjeff
Super Member
MI
kubota l2850, kubota l4150
So questions for knowledgeable jd 212 and 214 enthusiasts. I own 2 older than me I think 212s one with working mower deck one one without both ran great especially considering age. and a POS problem riddled non running 214 one of the 212s starter went out. Does the engine need to be pulled to change it? if so what else should be looked at possibly replaced with the engine out? Does a starter from a 214 kohler fit the kohler 212 I think so but have been wrong before. If only I had tiny hands I probably could get at the starter mounting bolts. Thanks for knowledge.
You might want to do a internet search for "replacing the starter on a jd 212 lawn tractor"
This was the first thing that came up:
Richard
Thanks, battery box removed awhile ago to try and remove starter. I'm also taking off a few less worn parts off the old 214 to put on the 212 for a shady tree rebuild lol. will try different extensions and u joints for my 3/8" sockets. I guess I don't have the dexterity I used to have get into tight spots anymore. Might still end up pulling the motor anyway.
2019 Ford F-350 (A55973)
2019 Ford F-350...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
New Holland T2420 (A53317)
New Holland T2420...
CATERPILLAR 255 SKID STEER (A52709)
CATERPILLAR 255...
2018 Dodge Ram 5500 4x4 Crew Cab Flatbed Service Truck (A55973)
2018 Dodge Ram...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
