Baling leaves with a square baler
/ Baling leaves with a square baler #1
m5guy
Augusta mi
mm m5, z, McCormick ct 41 hsv
So, I have an outdoor wood burner and a yard full of oak trees. I also have an old new holland square baler collecting dust. So I thought I would try baling my leaves and burning them in the outdoor burner. Took some trial and error, but it works surprisingly well. I need to make the bales as small as you can for my burner, as I found a full size bale will choke out the fire. Just an idea if you have lots of leaves and like doing things that make your neighbors question your sanity.
/ Baling leaves with a square baler #2
Cool! Could you bale full size and feed wafers?
Can I ask? ... What NH baler do you have?
I did that last year, it's kinda of a hassle that way. I have a nh 273. 1974 vintage I believe.
/ Baling leaves with a square baler #4
How do you get the leaves dry enough to burn vs just smolder? Seems like around here they are damp 99% of the time when I rake or mulch them.
Great idea on getting some use out of baler and leaves.
/ Baling leaves with a square baler #5
And when baling hay, you try as much as possible to keep leaves OUT of the bales lol
/ Baling leaves with a square baler #6
They are leaves not hay. The second you cut the strings you will have a bunch of loose leaves.
/ Baling leaves with a square baler #8
I could see people buying those for fall decorations or adding mulch to gardens if you lived in the right area. Neat idea.
/ Baling leaves with a square baler #9
If they smoke as much as they do when burning on the ground, your neighbors will love(not) you.
/ Baling leaves with a square baler #10
Messiness understood. Still, you have separate compressed strokes held stably for a time. It is an outdoor stove.
/ Baling leaves with a square baler #13
And while you are baling those leaves, be sure to wear one of those white oxford button down long sleeve shirts that you have no use for anymore. Especially with heavy starch. They will drive by very slowly and might even have their mouth open.
/ Baling leaves with a square baler #14
I'd encourage you to periodically check the interior temperature of your pile of bales. If it is a small pile it is probably OK, but moisture and piles of hay bales can have catastrophic results.
/ Baling leaves with a square baler #16
Fortunately since moving from a very wooded property in SE PA to a sparsely wooded lot in East Texas, I just mulch them in with my ZD1611.
/ Baling leaves with a square baler #17
Ours are very dry here in central Minnesota, we have a outdoor fireplace on our patio and I will shovel some from the patio into the fireplace and they instantly light on fire that you can’t stand to close when doing that.
/ Baling leaves with a square baler #19
I'm fortunate, my animals like the "potato chips" that fall from above. They do a pretty good job at cleaning them all up. Only ones I don't see eat them are the horses. :)
/ Baling leaves with a square baler #20
Watching the neighbors' reactions to that would be worth the price of admission! :):rolleyes::love:
2022 Caterpillar 906M Compact Articulated Wheel Loader (A56857)
2022 Caterpillar...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Brock 36'x17' Flat Bottom Grain Storage Tank (A57148)
Brock 36'x17' Flat...
TANK MANIFOLD (A58214)
2006 International Bucket Truck (A60352)
2006 International...
Roll of 2-inch Vacuum Hose (A57454)
Roll of 2-inch...
