Baling leaves with a square baler
   / Baling leaves with a square baler #13
and like doing things that make your neighbors question your sanity.
And while you are baling those leaves, be sure to wear one of those white oxford button down long sleeve shirts that you have no use for anymore. Especially with heavy starch. They will drive by very slowly and might even have their mouth open.
   / Baling leaves with a square baler #14
I'd encourage you to periodically check the interior temperature of your pile of bales. If it is a small pile it is probably OK, but moisture and piles of hay bales can have catastrophic results.
2015 Jeep Cherokee Latitude SUV (A55758)
2015 Jeep Cherokee...
11' CONTAINER (A52706)
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2008 Featherlite Portable Office Command Center T/A Trailer with Wacker Neuson G50 Towable Genera... (A56858)
2008 Featherlite...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A55315)
2023 Kubota...
