Baling leaves with a square baler
   / Baling leaves with a square baler #13
and like doing things that make your neighbors question your sanity.
And while you are baling those leaves, be sure to wear one of those white oxford button down long sleeve shirts that you have no use for anymore. Especially with heavy starch. They will drive by very slowly and might even have their mouth open.
   / Baling leaves with a square baler #14
I'd encourage you to periodically check the interior temperature of your pile of bales. If it is a small pile it is probably OK, but moisture and piles of hay bales can have catastrophic results.
   / Baling leaves with a square baler #16
Fortunately since moving from a very wooded property in SE PA to a sparsely wooded lot in East Texas, I just mulch them in with my ZD1611.
   / Baling leaves with a square baler #17
How do you get the leaves dry enough to burn vs just smolder? Seems like around here they are damp 99% of the time when I rake or mulch them.
Great idea on getting some use out of baler and leaves.
Ours are very dry here in central Minnesota, we have a outdoor fireplace on our patio and I will shovel some from the patio into the fireplace and they instantly light on fire that you can’t stand to close when doing that.
   / Baling leaves with a square baler #19
I'm fortunate, my animals like the "potato chips" that fall from above. They do a pretty good job at cleaning them all up. Only ones I don't see eat them are the horses. :)
   / Baling leaves with a square baler #20
Watching the neighbors' reactions to that would be worth the price of admission! :):rolleyes::love:
2020 Toro Pro Sweep Vacuum (A55758)
2020 Toro Pro...
STAINLESS STEEL WARMING STATION ON WHEELS (A58374)
STAINLESS STEEL...
CAT IT18 (A55272)
CAT IT18 (A55272)
2023 HELI CPYD25C FORKLIFT (A58216)
2023 HELI CPYD25C...
2012 Ford F-550 Ext. Cab Stellar EC3200 1.5 Ton Crane Utility Flatbed Truck (A55973)
2012 Ford F-550...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
