Baling leaves with a square baler
   / Baling leaves with a square baler #1
m5guy
Augusta mi
mm m5, z, McCormick ct 41 hsv
So, I have an outdoor wood burner and a yard full of oak trees. I also have an old new holland square baler collecting dust. So I thought I would try baling my leaves and burning them in the outdoor burner. Took some trial and error, but it works surprisingly well. I need to make the bales as small as you can for my burner, as I found a full size bale will choke out the fire. Just an idea if you have lots of leaves and like doing things that make your neighbors question your sanity.
   / Baling leaves with a square baler #2
Cool! Could you bale full size and feed wafers?
Can I ask? ... What NH baler do you have?
I did that last year, it's kinda of a hassle that way. I have a nh 273. 1974 vintage I believe.
   / Baling leaves with a square baler #4
How do you get the leaves dry enough to burn vs just smolder? Seems like around here they are damp 99% of the time when I rake or mulch them.
Great idea on getting some use out of baler and leaves.
   / Baling leaves with a square baler #5
And when baling hay, you try as much as possible to keep leaves OUT of the bales lol
   / Baling leaves with a square baler #6
They are leaves not hay. The second you cut the strings you will have a bunch of loose leaves.
   / Baling leaves with a square baler #7
I don't touch leaves. I run them over with one of my mulching mowers and it's like "they never even happened".
   / Baling leaves with a square baler #8
I could see people buying those for fall decorations or adding mulch to gardens if you lived in the right area. Neat idea.
  • Good Post
Reactions: D&D
   / Baling leaves with a square baler #9
If they smoke as much as they do when burning on the ground, your neighbors will love(not) you.
   / Baling leaves with a square baler #10
Messiness understood. Still, you have separate compressed strokes held stably for a time. It is an outdoor stove.
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A56435)
2006 Heil Tanker...
1667 (A57192)
1667 (A57192)
2010 KMC 3376 Peanut Combine (A56435)
2010 KMC 3376...
2015 Freightliner Bucket Truck - Terex TM 100 Boom - Cummins Diesel - Allison Transmission (A55315)
2015 Freightliner...
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
2019 Freightliner Bucket Truck (A55973)
2019 Freightliner...
