Shock Absorbing Hitch
/ Shock Absorbing Hitch #2
I've never used one of these. Are they worth the extra $$? I've linked one as an example, not necessarily what I would get.
https://genyhitch.com/product/boss-torsion-flex-16k-drop-hitch/
I think that the one you linked to is probably ok to take some of the bumps out, but there may be better choices that offer more degrees of control.
I would ask why you want one and what you hope to get out of using it.
I've used the equal-I-zer version for probably 25 years. It uses torsion arms to add some weight back to the truck, while keeping the trailer ride much smoother. Our animals seem to do well, and it definitely gives the truck more control over the trailer, both in cross winds, and reducing tendencies to fishtailing. I used it on a dually one ton and you practically didn't feel the trailer behind. (Both 2 and 4 horse trailers.) Even with a lighter single axle pickup, the trailering always seems controlled.
For trailering animals, I would always use it.
All the best,
Peter
/ Shock Absorbing Hitch #4
I have a load leveler that I used to use with a travel trailer. It's anti-sway is a pair of shock absorber pistons that go from the hitch to the trailer tongue. Of course, the one time I needed it, hauling hay, I didn't have it installed.
I pull a 16' box trailer, a car hauler to move tractor or ventrac, and soon to be dump trailer. I'm not moving livestock or pulling an RV. I would just be looking to even out the ride a bit. I'm asking because I'm not sure my applications justify the expense.
/ Shock Absorbing Hitch #6
I would not underestimate how much lighter the steering gets when pulling a heavy trailer. Load leveling hitches put more weight on the front steering, given you more control.
Lots of folks do trailer without load leveling hitches, so, for sure, probably not required, but I find it makes trailering less of strain.
If you are looking to get the bumps out, and a bit more level, a set of rear air bags added to the suspension can help level the truck against variable loads.
All the best,
Peter
/ Shock Absorbing Hitch #7
Many people have the different cushion hitches, some swear by them some swear at them.
The Shocker air cushion one seems to be a favorite of many.
One issue with some and with the one pictured is the distance it moves your hitch point rearward, which gives your tongue weight more leverage on your hitch and front end.
UNUSED WOLVERINE BC-13-72W 72" HYD BRUSH CUTTER (A62131)
UNUSED WOLVERINE...
KJ 10' FORK EXTENSIONS (A62131)
KJ 10' FORK...
UNUSED SDLANCH DIAMOND PLATED PLASTIC MATS (A62131)
UNUSED SDLANCH...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Snap-On Zeus Diagnostic Machine (A63118)
Snap-On Zeus...
Solesbee Hydraulic Thumb (A61166)
Solesbee Hydraulic...
