Dump Trailers
/ Dump Trailers #1
Jason05216
Member
Missouri
JD X720 Kubota B2601 Ventrac
I've got a 2025 Ram 2500 with the Cummins. GVWR is 11040. I'm looking to get a dump trailer. I'm going to go with a bumper hitch rather a gooseneck. Heaviest thing I would probably haul would be gravel. Probably also going to haul mulch, etc. I'm not planning to haul any vehicles in it, I've seen a few with ramps for that purpose. Looking for input on things I should consider. What size makes sense? Brands that you would recommend or stay away from?
/ Dump Trailers #2
My 5x10 is about the same tire track width as my ¾ ton GMC. I like that. If I was going to use it more often, I might look for a 7x14, but then I would have to be much more attentive to it, to stay in my own lane and around corners.
/ Dump Trailers #3
Any amount of gravel can get heavy quick at 2,500 to 3,000 lbs a yard. I would reconsider the gooseneck. The other benefit of a gooseneck is that it prevents a lot of friends from having the means to borrow it compared to a bumper hitch.
/ Dump Trailers #4
I bought a Homesteader 6x10, #9900, with sides that open. I haven't even used it yet. I wanted the fold down sides so I could side load it with pallets.
So far, it looks pretty good. It does not come with ramps, I've yet to ask why, but I don't think they want you driving stuff into it. Maybe a liability thing.
/ Dump Trailers #5
Not to try to talk you out of it, cause I would love to have a 9999# dump trailer.... Do you realize just how small 3.5T or even 5T of gravel really is? Heck, even 18T in a dump truck doesn't go far, and then think about that being 6 trips? Yes, I want a dump trailer, no it doesnt make $$$ sense for me to buy one.
/ Dump Trailers #6
May I ask why? GN is so much more balanced and utilizes your front axle more. It puts the weight further forward on your truck. Your Ram was literally built to pull a GN trailer.
As soon as I get my dump truck sold, I’m buying a 25,000lb dump trailer with a gooseneck hitch.
Most come with a basic set of slide out ramps that clip onto the rear of the trailer. They are designed for smaller tractors, excavators, etc.
Based on the brief description of what you are doing I would say 12’-16’ would be good.
I have a Kaufman 38,500LB gooseneck trailer that has been very, very good to me. I found it was priced real good for the value it has given me. 6 years in service, used weekly, loaded to max capacity and just one failed brake drum.
If you want to go top shelf, check out Diamond C.
/ Dump Trailers
Mostly because I've got a bed cover and bed rug and didn't want to mess with having to get the bed set up for GN. I'll look into the GN, maybe it would work ok with my set up.
/ Dump Trailers #8
A BP trailer puts all the weight behind your rear axle and really once you use a GN, you immediately unlock so much more potential from your truck.
You are correct that it takes up space in the bed, but you’ll quickly figure out ways around that.
/ Dump Trailers #10
If you are concerned about the ROI, I would do the math on how many loads of whatever you need against the cost of hiring someone with a big dump truck to do the work. Around here the trailer cost is way more than having someone else do it, for more gravel than I would ever use.
To me it pencils out only if you need a little bit at a whole series of dumpsites, like being a landscaper, with clients.
But if you do buy a trailer, I'd go with a gooseneck; better load distribution, more capacity, and a better behaving trailer. You can have hitches that are removable, if you really need the bed space for some reason.
All the best,
Peter
/ Dump Trailers #11
I also place a great deal of intrinsic value on “time”. If I have my own dump truck or dump trailer, I can be on the road getting material in 15 minutes v. waiting for delivery. I can also work after hours or weekends when there’s little help available from a vendor.
That is a huge plus to ownership that is frequently overlooked.
All the best,
Peter
Agree
/ Dump Trailers #12
That load of sand was 5.3 tons. I usually only haul gravel, dirt or sand if I can finish the job with 5 tons. Otherwise it’s cheaper and faster to call a dump truck. I use the dump trailers plenty for hauling light material but hauling gravel isn’t a productive use of time.
/ Dump Trailers #13
I hate 14k gooseneck trailers. At 20k they kinda become a necessity but a 14k bumper pull trailer pulls fine. I don’t want to give up my bed capacity plus have to work harder hooking it up just to pull a 14k trailer. I set something on the bed and pull a trailer behind it all the time.
/ Dump Trailers #14
I think the 7' x 14' is a good size trailer for the occasional but serious user. It is also popular and holds its resell value really well. It's better suited for hauling a smaller compact tractor with loader than a 6' x 12', for example. And they pull really well -- much better than my equipment trailer that bounces around and beats you up when it's empty.
The ramps are for small equipment like tractors, etc. -- not for cars. Mine has jack legs on the rear that you can drop when loading equipment so the hitch isn't taking all the load and trying to lift your truck bumper. (That's a feature that is worth looking for.) Also consider the different height sides of the trailers. Having the ability to add side boards is a also a good feature.
I've seen Moritz trailers that have really neat latches that catch and secure the rear gates when you swing them open. It's important that they're secured before you lift the bed -- if they swing closed when the bed is going up you can tear something up. Mine just uses chains to keep them pulled back and that's ok too, but not as slick as the Moritz hardware.
Ramps that slide out from underneath are WAY BETTER than ramps that hang on the side of the trailer. They are heavy and hard to handle so look for slide-out ramps.
A tarp roller on the front is a must for hauling in a lot of locations.
Many will have a plug hard-wired up-front so you can just plug an extension cord in and it will power a charger and keep your battery charged and ready to use. No biggie, but it's convenient.
I've used Sure-trac and Moritz trailers and thought both were solid. Also used a PJ trailer and it didn't have some of the features that the others offered.
I found mine listed for sale used on FB for a great price. Was lucky enough to see it right after it was listed and jumped on it. You can't lose money on it if you buy it right and take care of it.
/ Dump Trailers #15
yes some application it doesn't make sense but for low quantity it can, you have to take account the delivery price which vastly varies depending on your location and sometime you need to rehandle the material since a dump truck can't go where you want it to go... it was my case when I did my horse ring, a dump truck simply couldn't go where I wanted so I rehandle everything with the dump trailer... Also like myself I get a healthy discount per tonnes for loading and hauling it myself so it makes it worth while.
/ Dump Trailers #16
Dump trailers are also really handy haulers -- even when not using the dump feature. For lumber or material on pallets or . . . heaven forbid . . . helping someone move . . . it's great to load up and close the rear doors and drive. I often use mine to pick stuff up that could also go on a equipment trailer, but the dump trailer pulls so much better. Unless you need to be able to load from the side using a forklift, the dump trailer will often beat out the equipment trailer for ease of use.
/ Dump Trailers #17
I hate 14k gooseneck trailers. At 20k they kinda become a necessity but a 14k bumper pull trailer pulls fine. I don’t want to give up my bed capacity plus have to work harder hooking it up just to pull a 14k trailer. I set something on the bed and pull a trailer behind it all the time. View attachment 4327199
You are missing the point
Your truck is built heavier than the OP.
Yours handles a BP better than the OPs
/ Dump Trailers #18
I agree with all of what you are saying for the benefit of goose neck, yourself being a commercial contractor it make perfect sense but I also would stick with bumper pull, ops has plenty of trucks, depending on the amount of use and length of pull I would argue a bumper is a lot cheaper set up to run especially if you are not set up for it.
/ Dump Trailers #19
I switched from a 14' GN scissor-lift to a 14' bumper pull hydraulic ram dump trailer. I can't tell that much of a difference in the ride. I definitely recommend the hydraulic ram for a dump trailer, never have to worry about it not being able to dump the load.
/ Dump Trailers #20
That’s true. I’ve pulled 14k trailers with single wheel trucks and it definitely bounces more than my dually but it’s acceptable. If I was pulling the trailer 1,000 miles a week well the first thing I would do is get a dually but to stay on topic I’d rather use a GN. If I was pulling the trailer once every couple weeks I’d get the bumper pull. I probably wouldn’t pull the trailer and put a pallet on the bed with a single wheel truck.
2022 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2022 FREIGHTLINER...
2010 KEYSTONE LAREDO (A65643)
2010 KEYSTONE...
2020 Club Car Carryall 700 Gas Utility Cart (A61567)
2020 Club Car...
2013 DODGE RAM 2500 CREW CAB TRUCK (A64280)
2013 DODGE RAM...
2025 Auger Bits Skid Steer Attachment (A61567)
2025 Auger Bits...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
