Adapting JIC from 3/8” to 1/2”?
/ Adapting JIC from 3/8” to 1/2”? #1
threepiece
Farmington, Mi
Kubota L3400 John Deere110 TLB Wheelhorse 520H
This project has turned out to be more complicated than expected and I’m barely halfway through.
I simply want to connect a control valve to the quick couplers. The control valve has six 3/8” male JIC ports with 9/16”-18 thread. The six quick couplers have 3/4”-16 male JIC threads.
So simply put, I want to connect a steel line to a device with a 3/8” male JIC on one end and a device with a 1/2” male JIC on the other.
It seems like a simple process but I can’t find a way with either 1/2” or 3/8” steel lines. Is this possible.
/ Adapting JIC from 3/8” to 1/2”? #4
I have ordered from them for years. I really like their hydraulic hoses.
/ Adapting JIC from 3/8” to 1/2”? #5
The valve has adapters screwed into the ports, they are most likely ORB/SAE ports. So, just get different adapters.
That was my original plan and where it became complicated.
Each spool has two ports with fittings. One fitting is a standard ORB however the other is special. It appears to be an ORB with an additional groove cut into the bottom with an O-ring.
If you look carefully at the above picture in post#1, you may see deformation on the sealing surface. If I can’t achieve a seal under this condition I will deposit braze or weld and re-cut the end.
/ Adapting JIC from 3/8” to 1/2”? #7
Are you the guy that bought the valve for $1 or some crazy price at an auction?
If so, you're paying for it now, LOL. Good luck. Cheap or free isn't always a good deal.
If not, it seems crazy that a regular spool valve has two different ports.
/ Adapting JIC from 3/8” to 1/2”? #8
If I understand correctly
On one hand, It seems like you laugh and ridicule me for trying to be frugal and repurpose this valve.
On the other hand you seem to have my sympathy if I purchased this valve new.
Some folks will see this situation in the opposite way. There is a bigger picture here that apparently you are not privy to.
/ Adapting JIC from 3/8” to 1/2”? #10
I think you made a great score on those valves, even if it will take some time to figure out a couple fittings here and there, which frankly, is a minor issue.
When I built the loader for my tractor, I also bought an used valve for around $40. It's a Rexroth valve and I believe it came out of an older Case skidsteer. It has float on one spool, work port anticavitation and relief valves, load check valves and great feathering control. You really can have fine control with it.
In my opinion, a great score for the price. I can't even imagine what it would have cost me to get a new valve with all of those features. Well beyond $500 I'm think. Heck, I don't have more than $300 on all the hoses, fittings and valve on the entire loader.
Long story short, I would have done the same as you in an heartbeat.
/ Adapting JIC from 3/8” to 1/2”? #11
Are you looking to directly (or as directly as possible) connect the quick connects to the valve, or would there be hoses between them? In the pictures they seem separated, but maybe you are changing that?
If direct connect, you can get female to female JIC swivels with different sizes on each end. I agree with others that its also worth checking whether the valve end are ORB. They sure look like it, but you thought some were not? If the are, I'd look at removing the ORB to JIC Male, and look at replacing with an ORB to JIC Female that will connect directly to the couplers? Also check the couplers to see if they are actually ORB with JIC fittings attached? Maybe an ORB male to ORB amle will allow a direct connection without all the intermediate adapters.
Yes, I bought this valve at the scrap yard for about $4.
The issues I am having have nothing to do with the valve and everything to do with my desire to plumb it with steel lines as opposed to flexible hose. Had I chose to use flexible hose this installation would have been done two weeks ago and this thread would not exist.
This is my first endeavor into hydraulics. While I may be paying a price for doing it this way, I am also getting an education that I will likely use in the future. A good deal if you ask me.
I plan to plumb with 1/2” steel tubing from the valve to the connectors. I want to use flexible hose only where flex is necessary.
The coupler body is essentially one piece with a 1/2” JIC machined on the end.
While the six fittings in the work ports look like ORB, three of them are special. The special ones have an additional O-ring on the bottom face. I’m not sure the purpose but I don’t want to change anything there. All six fittings have 3/8” male JIC to connect to.
I have a ridiculous amount of time in this project because my shop is 200 miles away, I have little hydraulic experience and a stubborn desire to archive a clean installation.
/ Adapting JIC from 3/8” to 1/2”? #14
I have a problem with making things work were they should not. Sometimes it costs me way more money than if I did it with proper stuff. Generally I end up hating the extra work it caused me, but I keep trying to shoe horn stuff together. So what your doing seems like a fun challenge.
I would use 1/2" tube.
On the valve end I would use flared fittings
Parker 8BTX-S nut and 8TX-S sleeve. They are pretty affordable. There are other brands but I am lazy and don't want to look their part numbers up.
Next I would ditch the bulkhead fittings. I am assuming you have 1/2" npt couplers. In their place I would use 1/2" tube bite style to 1/2" NPT bulkhead couplers. There might be other brands but the Swagelok SS-810-1-8 fits the bill
Its probably cheaper to use hose, but whats the fun in that.
/ Adapting JIC from 3/8” to 1/2”? #15
I have never made rigid hydraulic lines, but imagine it requires a certain amount of specialized equipment and materials to deal with the high pressure. What sort of pipe? How do you bend it? How do you put a JIC flare on the end? What sort of nuts and collars or other stuff is needed? I don't think it's like working with copper pipe, or even brake line pipes. Maybe someone has experience fabbing hard hydraulic lines and can speak to this?
/ Adapting JIC from 3/8” to 1/2”? #16
Its more like bending conduit since you cannot really undo the bend, and your trying to line everything up. For 1/2" I use carbon steel or stainless seamless tubing.
To bend it I use a Parker #8 sliding block. For larger tubing I use geared Ridgid benders.
To flare it I use a Ridgid 377 that has an eccentric head so it is not trying to flare all the tube at once.
To cut it I use a Ridgid 15-SI cutter with the correct wheel for stainless
To deburr it I use a Ridgid 223S.
To put a fitting on the end you have two main options:
Flareless.
These are bite to tube fittings, you cut the tube, deburr it, then clean the outside, slide it on then tighten the collar. The advantage of this is that you can get lots of different types of threads, the downside is they are expensive and bulky.
Flared fitting.
Your mostly limited to female JIC 37 degree, or SAE 45 degree of the size that your tube is. They are cheap, and compact. Downside is that the require special tools to make, and you are limited on thread options.
Also I suck at it. Buy 3x the tubing I need and cuss at it the whole time as I fill the scrap bin. Having the right tools does not mean your an expert.
/ Adapting JIC from 3/8” to 1/2”? #17
Doing this with metric tubing would be as easy as it gets. Pretty much just needed a tube bender for the bends and a pipe cutter (not necessarily needed but makes the job easier).
DIN2353 crimp fittings would make it very easy and simple to use as there is no need for flare. Just slide the tube all the way inside the fitting till it stops and tighten the nut.
L series tubing would handle all the pressure that machine can produce and it's still easier to bend compared to the thicker S series tubing.
That's the route I went when I built the loader for a Kubota B7000 way back in the day. More recently, for the Branson, I also used hard lines but machined and welded the fittings on the tubing.
/ Adapting JIC from 3/8” to 1/2”? #18
That is the type of tube bite fittings I was refering to. Your skills with tubing fabrication are amazing.
/ Adapting JIC from 3/8” to 1/2”? #19
I was raised in the oilfields of west Texas
Town Odessa. Endless supply of just bout everything. Especially hydraulics
Other option…… machine shop
/ Adapting JIC from 3/8” to 1/2”? #20
The simplest way to plumb this would be to get 1/2 x 3/8 tube end reducers. They are just a nut and a male 3/8 jic that screws to the end of the 1/2 male but then you would need to use 3/8 lines.
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2025 14ft. Bi-Parting Driveway Gate (A59231)
2025 14ft...
2004 GMC Sierra 3500 Pickup Truck (A55973)
2004 GMC Sierra...
2016 Toro Groundsmaster 4500-D 4WD Commercial Rotary Mower (A59228)
2016 Toro...
2018 Ford Escape 4WD SUV (A59231)
2018 Ford Escape...
