Buying Advice Friend needs to replace a Kioti CK30 due to rotary cutter "bush hog" weight
/ Friend needs to replace a Kioti CK30 due to rotary cutter "bush hog" weight #41
With a brush hog or rotary cutter attached, a wheelie isn't going to happen, other than possibly a few inches before the slack in the mower bottoms out.
I would question the wisdom of the thin little straps on the back of a bush hog preventing a rear roll over.
I am pretty sure you can have a small child bend the rear braces by hand as 1/4"x2" has very little compression strength. The upright mast is just held on by a single bolt on each side, creating a pivot point.
His mower is a heavy duty unit not some cheap Chinese made thing from Harbor Freight, TSC, Atwoods, etc.
/ Friend needs to replace a Kioti CK30 due to rotary cutter "bush hog" weight #43
The
My friend bought a 5' Everything Attachments heavy rotary cutter, aka Bush Hog, and has been using it with a compact Kioti CK30 (think that is the correct model number). While it was a good tractor with the lightweight, disposable Kioti rotary cutter, it isn't really safe around his dam and is generally poorly 'balanced'.
He needs a compact tractor since he clears trails in trees where the lanes are pretty tight. Looking for a replacement in East Texas via TractorHouse and TractorData, I'm not seeing anything that jumps out at me.
I remember seeing an older Massey 26xx something with a Perkins engine that was an older operating station model, but I can't seem to find it today. Kubota and John Deere rule around here with some Mahindra and TYM support.
What tractor models do EA 5' rotary mower owners have that are appropriate for mowing rough trails and the backside of a dam? I am looking for something safe, as he was lucky to remain uninjured when the Hydrostat starved of oil and he rolled backwards down a big dam. Width and height need to remain reasonable for "walking" trails in trees where he blades rain washouts and picks up downed limbs and cut up felled trees.
Please ignore the AutoCorrect/AI madness in this post ... 😡
The solution is to buy a 4' mower and sell the 5'; too much mower for that tiny tractor IMO.
The hydrostatic losing pressure means he needs a gear drive instead for mowing that dam.
Our dam is about 35°, I mowed it with my old H.Ferguson 30 and a 4' rotary mower, only going downhill in low gear.
I did make sure the ground and grass was dry first.
/ Friend needs to replace a Kioti CK30 due to rotary cutter "bush hog" weight #44
Yes. There is just the small but notable benefit of suspended weight going to ground. A warning/2nd chance to do the right thing.
/ Friend needs to replace a Kioti CK30 due to rotary cutter "bush hog" weight #45
Not trying to be a jerk. But the photo with the thin little straps is from this link.
I still stand by my point that the thin braces on the bush hog have little stopping power on a rearwards roll.
/ Friend needs to replace a Kioti CK30 due to rotary cutter "bush hog" weight #48
Could he get some front suitcase weights?
I’d imagine it’d probably be possible to weld up a bracket for them on the front of the tractor.
Probably cheaper than another tractor anyways.
I needed to weigh down a Ford 2000 diesel and built a bracket for the front as suggested here. Home Depot had 8x16 solid concrete, not cinder block but the heavier.....very heavy to pickup with your hands, and I think it was 4 maybe 6 on the bracket strapped down. Did the job.
Other thing is rear tread width. Increasing that will surely help stability on dams especially if you mow along the dam rather than up and down. I got a piece of 8" diameter steel pipe and cut 2ea. 4" sections....4" because that would set the outside of the rears just within the width of my mower. I made a diagram of the axle's 6 hole mounting dimensions and took it to a machine shop where they made mounting plates out of 1/4" sheet steel.
Brought it home and welded it up and walla better stability.
/ Friend needs to replace a Kioti CK30 due to rotary cutter "bush hog" weight #49
I mentioned the possibility of a torque wheelie on a hillside. It is a valid point that the trailing wheel will largely remove the weight of the implement from the tractor. And the implement itself will provide some overall stability.
The bars to the top link would generally be designed for tension. A 3 point hitch will tend to float up a little if tension is released with the implement on the ground.
It is definitely not designed as wheelie bar on a dragster, but it may take a little force. An A-Frame design is always good.
/ Friend needs to replace a Kioti CK30 due to rotary cutter "bush hog" weight #50
I'd be inclined to let it go wild and once a year or two cut down any saplings with a weed eater with brush blade. Hire someone if hes not able. Tree roots are what you don't want.
How big an area is that needs cutting? Aggregate cover being that steep?
2013 Ford F-250 Pickup Truck (A59230)
2013 Ford F-250...
2020 CATERPILLAR 306CR EXCAVATOR (A60429)
2020 CATERPILLAR...
167 (A52708)
167 (A52708)
(2) NOS-8 LUG- 7000Ib 74SC-93 HUB FACE DROP AXLES (A60432)
(2) NOS-8 LUG-...
10' CONTAINER (A60432)
Caterpillar 320 (A60462)
Caterpillar 320...
