Ownership likes and dislikes
   / Ownership likes and dislikes #1
yanmars
Many have a favorite color tractor and swear by them and swear at the others. For those that own a TYM please advise the good and bad. Never owned one but have potential interest.
   / Ownership likes and dislikes #2
I've had mine three years, never had an issue, dealer has been great for regular maintenance parts
   / Ownership likes and dislikes #3
I would readily buy another TYM. I bought the two tractors I have primarily due to the availability of engine components. The Mitsubishi S3L series engines were used by a lot of manufacturers, in a lot of applications, and parts are readily available, at relatively low cost.
But, if buying new would shop around a bit. Since Covid, getting some of the parts out of Korea has been problematic, but the dealer I go through sells and services several brands and says that seem to be universal right now.
   / Ownership likes and dislikes #4
TYM654. Didn't come with a temp gauge, biggest complaint. I did figure out a work around with an aftermarket gauge. I'll let you know if I think of anything else.
   / Ownership likes and dislikes #5
1) They cost quite a bit less than green or orange. In most cases, a lot less. This goes for new or used.
2) They are relatively simple, reliable and don't require expensive OEM fluids or filters in most cases.
3) I like the fact I was able to speak directly to a TYM regional rep when I had problems with my T224 before I took delivery of it. I also like that I have a "platinum" dealer within 100 miles of me.
The bads are going to be the same with any Asian, Indian, etc import. The rubber, plastic and soft parts tend to not take the elements well. Some welds and metallurgy can be iffy as well, but I think a lot of the bends and breaks you see people post up are due mostly to operator error.
I would not have a lot of faith in a TYM that needed to be used hard daily, commercial use or something I relied on to make a living.
   / Ownership likes and dislikes #6
My T25 has been great and I’ve worked it hard. No weld or plastic issues. Fit and finish is actually pretty damn good. Came with rear remotes and lights on the rops. Also Bluetooth speakers and wireless charging, but I haven’t tried those yet. Also has a 6 year drivetrain warranty.
I think it’s already paid for itself in 2 seasons. Currently using it to do a driveway up north. No disrespect to the person above me, but I wouldn’t judge the whole line on one model.
   / Ownership likes and dislikes #7
I just passed my 1 year anniversary with my 4820C. So far, so good.
It does a good job with what I've asked it to do.
Here are my complaints.
I wish it has more hydraulic flow.
There is no options for factory remote additions.
   / Ownership likes and dislikes #8
I hear you. I'm just stating what I've experienced myself and what I've seen/read on the various forums and platforms for what that's worth. How many hours have you put on your T25 so far in 2 seasons?
   / Ownership likes and dislikes #9
I put 50 hours on last season and about to hit another 50 now. That’s going up every couple weeks or so. If I was there full time it would be higher.
Here’s my latest job, breaking through this old embankment to start a driveway. This is about 3.5 feet high and 10 feet or so deep of hard packed soil with rocks on the interior, and roots from the trees grew on top. This was old farmland that was sold off in chunks. An excavator would be the right tool for this job but I don’t have one, just a bucket and piranha bar :).
Still a work in progress. Have to clean up the entrance and shape it. Also need to use the box blade to dig down so I can put down a base. Pic is misleading, that’s a bit over 75 feet in length and will be probably 100 when I’m done.
   / Ownership likes and dislikes #10
I've owned 2 TYM tractors, a 2007 27 hp and a 2017 45 hp. Also own a Kubota L35. I like that the TYM was much less than other makes. That said they are not made as well as some of the other brands. I sold the 27 HP with about 1000 hours. My 45 hp has about 1000 hours now. About every seal that can leak is leaking. I changed the front axle seals one time but a few years leaking again so I run 00 grease in it now. I just let the rear seals leak. The display has gone out but Ive not replaced it yet. Ive had to weld the loader frame. I added some extra bracing and tack welded it to the frame so if the bolts get loose again it will hold. If I had the extra money I would have bought another Kubota instead. My L35 have not given any trouble. If You buy a TYM, you need to be a good mechanic and welder or have a great dealer close by that is willing to help when warranty is out
12ft 9in Altec Service Bed (A57453)
12ft 9in Altec...
2017 Jeep Wrangler Unlimited Sport (MPV), VIN # 1C4BJWDG5HL577343 (A57453)
2017 Jeep Wrangler...
FUEL PUMP W/NOZZLE (A58216)
FUEL PUMP W/NOZZLE...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55315)
JOHN DEERE ROW...
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
1968 Massey Ferguson 1100 Tractor (A59213)
1968 Massey...
