Mahindra 2538 HST
   / Mahindra 2538 HST
splitshot, thanks for the picture and update. Happy to see you got it done! It appears you used a transmission jack to support the axle for removal? Do i need to order gasket for the main body separation or did you use tube sealant? This is something i have never attempted. Any other suggestions are very much appreciated. Thanks.
   / Mahindra 2538 HST #12
bobstorage, no problem!
-yes, the transmission jack was a backsaver, especially when reinstalling. I also used a cherry picker/engine hoist to support the rops from above (that helped alot)
-for gasket material I used the black permatex, sealed it fine.
-I took my time (I'm retired) and PTL I knocked it out over several days.
-I have a boatload of photos if you need to see anything specific.
Suggestions?
-take plenty of photos along the way
-do one side at a time (your second side will go quickly)
-have multiple jacks on hand (especially if working alone)
-if you have a backhoe frame mounted. it will need to be removed from each side (just a few nuts and bolts)
-take advantage of having open access and clean your hydraulic screen filter and the center housing
-once you have the side housing off on each side, you will need to pop the bearing off before removing the gear to access the spring retaining ring/clip (removing and installing this clip was the most difficult part of the whole process)
-enjoy the experience!
Club Car Electric Cart (A55853)
Club Car Electric...
(2) ROLLS OF MISC CARPET (A54757)
(2) ROLLS OF MISC...
2012 Chevrolet Impala Sedan (A55853)
2012 Chevrolet...
2015 Ram 3500 4x4 Crew Cab Pickup Truck (A53422)
2015 Ram 3500 4x4...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2007 Club Car Cart (A55853)
2007 Club Car Cart...
