First tractor
/ First tractor #1
Redraider75
LG Long Agribusiness LT280D
New here, as stated above, I am the proud owner of my first tractor (at age 75), and it seems there are no owners manuals in existence!! So, in a last ditch effort, I am here asking for help/information on a LG Machinery/Long Agribusiness/LS/???? LT280D 28 hp Mitsubishi S4L powered 4 wheel drive compact tractor with front loader. Ideally, someone here has one of these tractors and a manual, but an owner of one with knowledge he would like to share would be great.
Simple info, like where is the fill access for hydraulic oil, what is the correct level (in the sighting glass on the rear of the tractor), how do I actuate the glow plugs........and on and on.
I really need access to manuals to make this process as simple as possible.
Any and all info would be greatly appreciated.
Redraider75
/ First tractor #2
Welcome. Look in the LS section of this forum for your info maybe.
Quick internet search, came up with this link to TBN.
/ First tractor #3
In my very limited experience, actuating the glow plugs happens when the ignition switch is in some position different from "run" and "off" and "start". All these functions are built into the same switch, reasonably enough. Maybe play with the switch looking for an unexplained position? Unless the glow plugs also have some indicator light somewhere, nothing will look different for the first maybe 10 seconds. My previous tractor had a little open window through which I could see a heating coil start to glow -- and the window looked like a perfect fit for poking a cigarette through it to light it.
/ First tractor #4
As long as you can see the line across the top of the fluid in the window it is OK, guessing it's an actual window, not a sight glass/tube ...
My fluid is dyed red, if it's fresh, and of the clear variety, it is kinda hard to see the "line"!
/ First tractor #6
Brand and model would be most helpful. In your description I see Long, LG, LS, and Mitsubishi. A general idea of tractor age may be helpful, too.
/ First tractor #7
Welcome and congrats. :)
/ First tractor
Thanks for the responses, the make is all, or some or none of the above mentioned brands. My research has pointed to a couple of old brands that were split off of mother company as tractor divisions on their own, then bankrupt and returned only to be absorbed by LS, who does not claim any responsibility for any owners info. I think it is an early to mid 2000's model. The dash panel says LG Machinery, the side metal says Long Agribusiness, and the plate on the frame states LT280D. When I search that info I get all kinds of tractors with that model #. My best hope was LS, when I emailed their home office I was curtly informed that "owner's manuals are given at the time of new sale".....goodbye!!!!!!
So, I called the nearest LS dealer and as nice as the gentleman was, he knew nothing of this brand, and wished me luck on finding what I needed. As some might have noticed, there are more than a few of us out here in the same predicament, needing and looking for information but nobody has come up with anything worthwhile.
The reference to Mitsubishi was to inform you of the engine only.
The key switch has off, on and start, and when you release off of start, it goes back to on, so I wouldn't think that on would be the glow plug energizer position.
Thank you again, hopefully a past owner will show up with first hand knowledge.
Redraider75
/ First tractor #10
No help with mfg / model, although some older tractors have the glow position opposite the run and start direction (CCW). There also could be a spring loaded position right before the start position, usually without a physical indicator.
/ First tractor
Thanks Eagle1, I have found that manual, and printed off all 197 pages(there goes my black printer ink), good info but not what I need the most.
I do have some new, good and bad, information, as I was able to spend some quality time with it this afternoon. I located the wiring to the glow plugs, traced in and back out of the dash panel, to a button I had never noticed before, and EUREKA I have functioning glow plugs and they make starting this thing fantastic!!!
I did find a partial label that tells me a phone number to call if I need an Owner's Manual(highly doubt it will actually pan out), but I will call it tomorrow with my fingers crossed. The label names this tractor as Long Agribusiness. which was bought out by LS as I understand things.
Now the bad, almost every electrical plug I can see is broken, with loose wires hanging everywhere! The important things work(as far as I know) so they may not be needed. It sure does eat at my nature to have all things correct with my equipment. May have to just shut my eyes when I work on the important stuff. The tach cable came out of it's sheath in pieces and until I figure out a way to gain access to the engine compartment it will have to wait. I am going to have to completely remove the engine cover to work on anything in there.
So for now I will continue to hope for a previous owner of one of these tractors to show up and adopt me till I become proficient in all things LT280D.
thanks again, keep the info coming
Redraider75
/ First tractor #13
Redraider75
Redraider, an older tractor such as yours is not a complicated piece of equipment, you sound like you are mechanically inclined, I believe, although I am not being much help here, that you'll be able to figure this out. As far as your wiring is concerned, attack each circuit one at a time, trace them out like you have started . . . you can do it.
/ First tractor #14
I don't know anything about your tractor but I do know about a tractor with a front end loader and I know you are gonna really enjoy using your tractor. And TBN is a great place for tractor info, Welcome!
Eric
/ First tractor #15
Here’s some info on the MHI SL engine.
  • s3l.pdf
/ First tractor #16
More
  • SL3 operation and maintenance manual.pdf
/ First tractor
Alright, more great information!!!! Thank you Doneill for your confidence in my abilities, I should be able to do this, but as far as the wiring problems go it will be an unbearable task without a schematic, and knowing nothing about the possible functions available! Most of which I probably don't even need. Right now I am just trying to figure out the necessary parts, familiarize myself with those and make sure they are in the best possible condition. That Mitsubishi information will definitely help.............thank you.
Keep it coming guys
Redraider75
/ First tractor #18
Redraider75
Key position for glow plugs is normaly anti-clock wise, it is spring loaded and has to be held in that position for about 10 seconds, release and turn to start. Later model tractors turn key to on and a dash light that looks like a spring will go out, then start.
/ First tractor
Update Alert............I was loosing hope on getting a manual for this tractor, then I did a search using the only MFG. name I hadn't tried, Farmtrac! There it was a service manual. The funny thing is, the manual offered for a Farmtrac tractor was labeled "Long Agribusiness" which is my tractor. Oh well, it seems as though it is only a partial manual, which I am glad to have, it does seem incomplete.
So, if anyone here gets wind of a wiring schematic for a Long Agribusiness/Farmtrac/LG Machinery(and possibly other brand names) for a model LT280D, drop a comment here please.
I did find that he tach cable is broken, so with more investigation I should be able to fix that.............I hope there are generic cables available through regular parts stores.
Anyway things are looking up and I feel a little better on getting info that I will probably need in the future.
Redraider75
/ First tractor
OK Guys, latest update.............not that good. My statement of having working glow plugs was incorrect. It seemed to work that one time but not since. Further investigation showed me something that made me really scratch my head. I seems that the "field fix" was a wire from the battery ground post up to the momentary switch on the dash panel(not a factory switch or wiring) then to the glow plug bus bar!!!!!! How is this going to provide any power to the glow plugs?
I am in the process of replacing both battery cables with new, cleaning contact areas for the best connection, and I have made me a death cable to make a quick connection from battery pos to the glow plug bus bar as an experiment.
I still cannot figure out where I add hydraulic/ trans fluid, so until I am able to find that, can I get access to add fluid by unbolting the 8 bolts that hold on the trans cover between my feet? Am I going to destroy a gasket in doing that?
I feel like I own the only one of these critters ever made, and they never published an owners manual for it!
Please help me if you can, otherwise, I will continue as one of the seven blind men that were introduced to an elephant, and they all thought it was a different animal.
Thank you
Redraider
(1) UNUSED 8.3-24 TIRE W/ 6 LUG RIM (A64280)
(1) UNUSED 8.3-24...
Fendt FT900 Tractor Wide Fender Kit (A63117)
Fendt FT900...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
2016 TAKEUCHI TB240 EXCAVATOR (A64279)
2016 TAKEUCHI...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2018 FREIGHTLINER...
