What did you BREAK this week?
/ What did you BREAK this week? #1
gstrom99
Elite Member
Butler County, Iowa
Deere 855, Deere 530R zero turn, Allis Chalmers D17 III, Polaris Ranger, Deere 3032E (SIL's), Yamaha Timberwolf 250, Husky saws, H & H 10k and Carry-On trailers
There's a What did you BUY this week? thread, so why not this?
I broke my 45 year old MIG welder.
/ What did you BREAK this week? #4
I broke my Eagle twin cylinder 60 gal vertical tank quiet air compressor...or it broke itself. Not sure but I have to take it apart and troubleshoot the problem soon. It sure made some odd noises while quitting. That can't be good.
/ What did you BREAK this week? #9
I'm not sure if I broke it or if it broke itself, but the auger in our ice maker has a piece broken off of the end towards the door. The ice maker stopped dispensing so I removed the bin and cleaned out some cubes that decided to grow together and stop it. It briefly worked, then stopped again. This time a small piece of plastic auger was jammed in it. It's working now, but it will probably need that $18 part.
/ What did you BREAK this week? #10
We went to install the 5th wheel hitch, getting ready to haul the camper. Wife grabbed the handle, I grabbed the other end. Mine came up, her's didn't. The handle broke! I was all ready to purchase another hitch but a friend did a search and found 5th wheel hitch handles. Who would have thought!
24 hours later, the hitch is installed and ready to go to work!
David from jax
Well the "you" part may not be right. How about what did "you, others, gremlins, time or somebody/nobody" break?
I didn't break my welder. I went to turn it on and the feed didn't feed.
I guess time broke it.
/ What did you BREAK this week? #13
All my stuff is old, like me, and I find things break in bunches. I've got a wooden culvert in a tractor road down in the woods that I put in over nine years ago.
Here it is 6 years ago during the spring run-off. The only time it usually flows.
But now it is living beyond it's time. The sides washed out some in a huge storm last summer and the planks are punky and broke without any support under them.
Last week I decided to do a half-azzed band-aid fix to to see if I could get a couple more years out of it. I headed down into the woods with some pre cut planks, screws, my old 14 volt DeWalt driver, and a half bucket of gravel in the M5640. After about the third screw the DeWalt just quit - bang - like the drive gear stripped. Call that broken number one. No problem - I walked back the the house got my 120 Volt drill/driver, hung my portable generator on straps off the L3010's bucket and headed back into the woods. I set the generator up on the ground and pulled the recoil starter. Second pull - bang - the starter rope jammed. Would to move in or out and I could see the spring all uncoiled inside the housing. Call that broken number two. Starting to get irritated I packed up the generator and drove it back home. When I got there I could smell gas in the garage and saw the generators plastic shut off valve was bent over and dripping gas. Apparently in my frustration I was not careful how I ran the straps under it coming home. So that is broken number 3. All in one morning.
I bought a new driver. Replaced the gas tank bushing and shutoff valve, and fixed the recoil starter ( the screw that holds the spring and pulley together came unscrewed ) on the 25 year old Generac 5000 and "fixed" the culvert yesterday.
gg
/ What did you BREAK this week? #14
Nothing, but then I really didn't do much last week, so that kinda lowered the possibilities.
/ What did you BREAK this week? #15
Grapple....again. Need to get the welder out. The new trackloader is just too much for it. Going to need an upgrade or I'm going to ruin this one.
/ What did you BREAK this week? #16
My knuckles trying to replace a bad O-ring on an O-ring face seal fitting on the 9570R.
/ What did you BREAK this week? #18
Broke my pitman arm puller trying to pop the steering stabilizer out of the steering link. Going to try the tie rod press tomorrow.
/ What did you BREAK this week? #19
Broke a cast spacer between discs on my heavy disk. Got it back together today. Spacer i found wasnt exactly same size but i think it will work. Length 9 inch and shaft size 1 1/2 were correct but ends not quite as wide.
/ What did you BREAK this week? #20
Broke automatic lube system on my big square baler. Greaser grenaded inside and pushed bits of plastic up into the main distribution block, which cannot be saved.
Greaser $1,050.
Dist’n block $950
Calibration of sensor for distn block $800
UPS shipping of parts $75.
$3 grand up in smoke and still not done baling. Still waiting on parts. Plus it rained for 5 days, further delaying finishing baling.
We are hoping bits of plastic didn’t make it past main block. If they did, I might have to replace the rest of the system for $ thousands more.
2023 CATERPILLAR 259D3 SKID STEER (A65053)
2023 CATERPILLAR...
2016 John Deere 85G Midi Excavator (A64553)
2016 John Deere...
EZ Guide 500 Remote (A65640)
EZ Guide 500...
Kubota KX080-4 Mini Excavator (A65579)
Kubota KX080-4...
Longhorn BBQ Bull Smoker (A65583)
Longhorn BBQ Bull...
2023 Schulte FX-318 Flex-wing Rotary Mower (A66285)
2023 Schulte...
