Buying House with Septic System
/ Buying House with Septic System #81
I wonder, in a finished house, how would an inspector even know sinks and tubs wernt piped into septic?
I would think this would be easy in a house with a basement or crawl space, where you'd be able to see more than one main waste stack. That would raise questions.
/ Buying House with Septic System #82
We have 2 septic systems. The house has 2 tanks, a leach field, and was 36" deep to the lids. When it came time to pump them the probe to find the lids went to the handle at the ground. The system for the stables has 3 tanks, a single 240' drain line, and they were only 24" underground, so easier to find. Now all 5 tanks have risers putting the lids 12" underground, much easier to locate. I try not to run over them with anything heavy. They get pumped every 3 years. We are in sand so they drain quite well, easy to spot the green grass where the leach field is.
/ Buying House with Septic System #83
In areas where you need a permit for everything, an inspector could make sure that everything at least had been purported to meet specs. No permit and signoff afterwards, it never happened.
If I was in an area of million dollar homes I would support that. In less populated areas where you aren't dumping wash water into your neighbor's well, it isn's so important.
/ Buying House with Septic System #84
Those are simple septic systems……how about this nightmare
I wire in some hideously nasty systems near the lake.
That Idec PLC in your cabinet seems to be a Siemens Logo!. I wonder if they can share software. Looks physically identical
/ Buying House with Septic System #86
In MI, its required by law that all septics be inspected prior to sale....for what good it does.
A month after we bought our house, I was paying for a whole new system. I wasn't to happy
5 grand but I had it put in with all new piping in the house. They sent it to the front of the house with no mound.
Sent from my SM-S901U using TractorByNet mobile app
Tell me more about this. So it failed a month after the inspection. I'm curious what does an inspection include?
/ Buying House with Septic System #88
Exactly! That is why when my realtor agent suggested the seller pay for a septic inspection, and they came back with "inspect what?" I had them pump out the tank and called it good. I was willing to accept the risk of the drainfield going bad with the price that I was paying for the property, so it really didn't matter. We figured since we had them "over a barrel" that we would use it to our advantage.
David from jax
/ Buying House with Septic System #89
So, here, you can get a certificate of inspection; they check tank (no way to visually see anything with drain field), they pump the tank completely out, make sure baffle and all is intact; then they fill with gray water, to the top, and time the rate to drop below the discharge. Then, they issue a certificate of inspection. If I remember right, they refilled again, and timed again, until they got to 500 gals of added and perked water, or the daily usage of a 3 bed room home. It only took about 15 minutes per add, and the drain field was given a clean bill of health
Edit; the water was added directly to the tank, not through the plumbing.
/ Buying House with Septic System #90
Well that is good to know!
Thanks, David from jax
/ Buying House with Septic System #91
There are other options...
/ Buying House with Septic System #92
Those inspection cameras are amazing, and I wouldn't let someone work on a leach field without one. You can see the issue, know where to dig, or where to hydrotreat.
All the best, Peter
/ Buying House with Septic System #93
If you have ever been around either sanitary or storm sewer camera inspection; step one is a hydro vacuum and jet clean, so that you can actually see what your looking at. You dont "swim" them.
Ive been around the smaller ones, with what appears to be an oversized Phish tape role, and a push camera; virtual identical to your cheap automatic endoscope, and the larger ones are often track drive, and only work in 8"+ pipe; but give exact footage, 360 degree, with zoom, and even gap measuring.
Im not saying it can't be done; but the stuff ive seen; you would need to pump and jet clean; go into the tank, remove the exit riser, and feed the camera in; if you dont have an accessible junction box. If you have an accesable junction box, you would still need the system pumped, and they wouldn't work in the drain field if holding water.
/ Buying House with Septic System #94
Maybe there are some kinda of tech that can see in gray water, but I dont know what that would be. Thermal wouldn't work, visual wouldn't work, would have to be some kinda sonic logging, looking for anomalies?
/ Buying House with Septic System #95
I did read through (scanned through, too many words...) the website; and I didnt see Anything about septic systems. Sewer systems should be generally dry, once you place an inflatable ball up stream. Septic is a full tank.
The also do make flush-able locate balls that you use a locator to find a tank that is difficult to locate. Again, thats the tank, not the leech field.
/ Buying House with Septic System #96
All the best, Peter
Unless you know something I dont (entirely possible), thats great for the drain lines from house to septic, or in a sewer system, house to manhole/grinder pump; but of no use in a septic tank, that is always full
/ Buying House with Septic System #97
In order to locate the leach junction box in the future I buried a few lbs of scrap iron pipe on top of it. That should be easy to locate in the future. And hopefully will protect the box from crushing with the backhoe. (Like we did last time :confused:).
/ Buying House with Septic System #98
Yes, my comment was directed to pipes, not tanks. I've seen inspections done on four inch pipes more than a few times and once on a three inch line (80 year old pipe, with a 0.5% slope).
Cameras are a reason why I try to use sweeps, rather than 90 degree elbows on lines that I think might need inspecting in their lifetimes.
All the best, Peter
/ Buying House with Septic System #99
So, for our OP, I would recommend your in-laws have it inspected, but speak to the inspection company and ask what all they are inspecting doe their price.
/ Buying House with Septic System #100
My in-laws are planning on buying a house with a septic system. I don't know anything about septic systems. When buying a house with a septic system is there a way to have a septic system inspected easily?
When we put in our septic, we wanted as large a system as we could get. Undersized systems just fail!
If you can see the county health dept records what was approved and installed, it could help.
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
2019 BOBCAT E26 EXCAVATOR (A63276)
2019 BOBCAT E26...
REDDICK OFFSET DITCHER, 3PT (A64278)
REDDICK OFFSET...
PALLET OF STAINLESS STEEL FEEDERS & WATERERS (A64278)
PALLET OF...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
2003 NOBLE 12000 GALLON WATER TOWER TRAILER (A65054)
2003 NOBLE 12000...
