Buying House with Septic System
   / Buying House with Septic System #81
I wonder, in a finished house, how would an inspector even know sinks and tubs wernt piped into septic?
I would think this would be easy in a house with a basement or crawl space, where you'd be able to see more than one main waste stack. That would raise questions.
   / Buying House with Septic System #82
We have 2 septic systems. The house has 2 tanks, a leach field, and was 36" deep to the lids. When it came time to pump them the probe to find the lids went to the handle at the ground. The system for the stables has 3 tanks, a single 240' drain line, and they were only 24" underground, so easier to find. Now all 5 tanks have risers putting the lids 12" underground, much easier to locate. I try not to run over them with anything heavy. They get pumped every 3 years. We are in sand so they drain quite well, easy to spot the green grass where the leach field is.
   / Buying House with Septic System #83
In areas where you need a permit for everything, an inspector could make sure that everything at least had been purported to meet specs. No permit and signoff afterwards, it never happened.
If I was in an area of million dollar homes I would support that. In less populated areas where you aren't dumping wash water into your neighbor's well, it isn's so important.
   / Buying House with Septic System #84
Those are simple septic systems……how about this nightmare
I wire in some hideously nasty systems near the lake.
That Idec PLC in your cabinet seems to be a Siemens Logo!. I wonder if they can share software. Looks physically identical
   / Buying House with Septic System #86
In MI, its required by law that all septics be inspected prior to sale....for what good it does.
A month after we bought our house, I was paying for a whole new system. I wasn't to happy
5 grand but I had it put in with all new piping in the house. They sent it to the front of the house with no mound.
Sent from my SM-S901U using TractorByNet mobile app
Tell me more about this. So it failed a month after the inspection. I'm curious what does an inspection include?
   / Buying House with Septic System #88
Exactly! That is why when my realtor agent suggested the seller pay for a septic inspection, and they came back with "inspect what?" I had them pump out the tank and called it good. I was willing to accept the risk of the drainfield going bad with the price that I was paying for the property, so it really didn't matter. We figured since we had them "over a barrel" that we would use it to our advantage.
David from jax
   / Buying House with Septic System #89
So, here, you can get a certificate of inspection; they check tank (no way to visually see anything with drain field), they pump the tank completely out, make sure baffle and all is intact; then they fill with gray water, to the top, and time the rate to drop below the discharge. Then, they issue a certificate of inspection. If I remember right, they refilled again, and timed again, until they got to 500 gals of added and perked water, or the daily usage of a 3 bed room home. It only took about 15 minutes per add, and the drain field was given a clean bill of health
Edit; the water was added directly to the tank, not through the plumbing.
   / Buying House with Septic System #90
Well that is good to know!
Thanks, David from jax
2019 Dodge Journey Crossroad SUV (A53424)
2019 Dodge Journey...
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB Crane Service Truck (A53422)
2013 Ford F-550...
UNUSED FUTURE FT-CWG72-72" HYD CURVED WOOD GRABBER (A57193)
UNUSED FUTURE...
American G-Model Pump Jack (A55315)
American G-Model...
2014 Jeep Patriot SUV (A55853)
2014 Jeep Patriot...
S/N: 5D121002416 (A55787)
S/N: 5D121002416...
