Looking for recommendations and advice for my first Post Hole Digger
/ Looking for recommendations and advice for my first Post Hole Digger
I bought the PHD from Tractor Supply that you are talking about. I already had the auger. I have used it a bunch to drill holes up to 48 inches deep. I use mine mainly for planting trees. Way easier than a shovel where I live. We have lotsa rocks and the auger just pulls them up. I am using a Yanmar YM2310 tractor to drive the PHD. It has 23 HP at the PTO. I have had to back the auger out twice by hand using a pipe wrench. Being smart for once I turned off the tractor both times before unscrewing the auger. No sense getting all wrapped up around an auger or PTO shaft. Anyway, I have drilled many holes and expect to drill many more with my setup.
Eric
eptm
Appreciate your experience with the TCS PDD. I do plan to use it to add small trees and looking forward to not using a shovel as in the past.
Good point about having to back out the auger so will include my pipe wrench and matching extension pipe to be prepared.
Fully agree with power off when you are manually engaging any PTO equipment. I now always do a safety briefing with my kids and grandkids including showing the PTO shaft safety sticker showing the person wrapped around the PTO shaft.
Thanks.
/ Looking for recommendations and advice for my first Post Hole Digger #12
CH4Ohio
My first use will be for installing vinyl 6 foot high stockade fencing at my Daughter's house and the instructions call for a 42 inch depth with a 10 inch diameter. So likely would benefit from your input and get the smaller 10 inch diameter auger.
I'd still get the 12" auger. More bang for the buck. The extra width will come in handy for transplanting potted plants, trees, etc. I was just pointing out that it's easy to get the auger hung up so you need to do quite a bit of up-and-down to keep the hole open and prevent that. Once it's screwed into the ground, you'll find your 3-point won't just lift it out.
/ Looking for recommendations and advice for my first Post Hole Digger #13
I think the best value for your money is the Countryline auger from Tractor Supply. The auger has replaceable teeth and digging tip. I've been using it for well over a decade now. It's my third auger, and by far the best for digging my red clay soil. Tractor Supply is terrible at keeping the teeth and tip in stock, but so far, I've been able to get them on Amazon.
I've done close to 1,400 feet of viny three rail fencing with it every 8 feet, and another 5,000 feet of horse fencing with wood posts at least every 100 feet, with some a lot closer. And also all my fencing for my dogs around my house, plus trees that my wife wanted and other things like a barn and light posts.
In my experience, getting the holes in a straight line is just about impossible with a 3 point auger. They start where you want them, but they angle or wonder off a little as you go down. All my holes are 3 feet deep. That's as far as I can get it to go with my tractors, and I've never needed them any deeper. Once the holes are dug, you will need a good clam shell digger to clean them up, and also dig the sides of the hole to get it lined up with the others. Expect to do this a lot when doing a straight fence with posts every 8 feet!!!! Roots and rocks will move a hole every time.
I started out with a 38hp tractor, and now it's on a 65hp tractor. The 38hp tractor had plenty of power to drill the holes, but not enough to pull it back out if it buried itself. I use a 36 inch pipe wrench to unscrew them, but I also have a length of 2 inch pipe that I put over the handle to get more leverage when it's really buried. Expect to ruin your entire day when you bury the auger!!! The 65hp tractor doesn't have this problem. Something that I came up with to help with the smaller tractor burying the auger was a set of blocks to stop it from going down any farther while using it. Once they gear box hits the wood, it stops digging and then it spins in the hole, breaking itself free.
I also have a 6 inch auger that I thought would be easier to do some metal pipes in the ground. But it got buried faster than the 12 inch auger, and it was so annoying that I threw it away. I never used it on my bigger tractor, but in all reality, there was never a need or use for the smaller auger. It's a lot easier to fill in a hole then it is to make it bigger after it's been drilled.
CH4Ohio
Good point as the 12 inch diameter auger is not much more cost and for the most likely future of tree planting will be better sized.
I am glad you pointed out the potential for needing to back out the auger manually if it gets stuck. Now I will have my large pipe wrench on-site if needed.
Thanks
Eddie
Appreciate your input from what you have experienced (you have put many feet of fence in for sure).
This project is a combination of vinyl fencing 8 foot on center (6 foot high) and chain link fencing for the daughters dog.
I will bring the clam shell digger to get the final dirt out of the hole. Also the timber sections for a positive stop on the depth. Also the pipe wrench and extension pipe that you and CH4Ohio have pointed out for manually backing out stuck auger. Good to know replacement parts are also available on Amazon.
Thanks for you information.
/ Looking for recommendations and advice for my first Post Hole Digger #16
I use a Danuser auger and I think they are among the best, but they are quite proud of them so for limited home owner use the others should be fine.
I have used the BX2660 to power my 24 inch bit in a pinch and it worked just fine in clay/small rock soil so you should be OK power wise.
Make sure you call Miss Utility even if you are sure there are no wires or pipes where you are working. It's free and covers you if something happens that they missed.
/ Looking for recommendations and advice for my first Post Hole Digger #17
Be aware that TSC offers 12 inch augers in both 36" and 48" lengths.
I have the 12" in 36", along with 6" and 24" diameter auger bits (also 36" length)
Wish I had gotten the 12" in 48".
FWIW, I've found that sticking the 6" diameter auger here in our clay soil is a lot easier than sticking the 2 larger ones. And when it gets stuck it is really stuck.
Make sure to lift all of them often to clear the spoils in the flighting.
/ Looking for recommendations and advice for my first Post Hole Digger #18
Do not waste your time with a standard auger, purchase the
smallest tree transplanting auger it will dig and dig and not
get hung up because it drills a tapered hole in the soil.
/ Looking for recommendations and advice for my first Post Hole Digger #19
Seems like reasonable advice ... if all he was doing was doing was transplanting trees.
But he's not ...
/ Looking for recommendations and advice for my first Post Hole Digger #20
Think of it just like a metal drilling bit with a tapered end.
The tapered holes he would be drilling in the soil eliminate
friction and binding entirely as he uses a tree transplanting
auger.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A59317)
2025 Kivel 48in...
TAKEUCHI TL6R SKID STEER (A59823)
TAKEUCHI TL6R SKID...
2014 Ag Spray Schaben Sidedresser (A56438)
2014 Ag Spray...
JLG 15 MVL MANLIFT (A58214)
JLG 15 MVL MANLIFT...
2007 PETERBILT FLAT TOP SLEEPER  385 (A60736)
2007 PETERBILT...
2024 Load Trailer 20ft T/A Flatbed Equipment Trailer (A56859)
2024 Load Trailer...
