Automatic gate openers
/ Automatic gate openers #1
jk96
Elite Member
Missouri
Kubota L6060
What gate openers do you like? After getting sticker shock ($15k plus for gates and openers) I have decided install everything myself. I have the gates already. Will be a dual swing 20 ft opening, two 10 ft gates, with solar, remotes, keypad entry, auto exit, and timer for keeping gates open during certain daytime hours.
Right now I am considering the liftmaster LIF-LA500XL40W-DUAL. This would be the lower end of their commercial line. The gate will be shared by us and two other homes.
/ Automatic gate openers #2
You can find a Genie or Craftsman garage opener, make an enclosure for it, and it will open and close a gate with the bracket off the chain. The hardest part is getting power out there.
BEST of all, the remotes will operate it too!
/ Automatic gate openers #3
Another setup, less than $500.
Thanks but Im looking for a plug and play option that's ready for install. Just wondering if there are others that I should also consider in addition to liftmaster. Ghost controls was another I've been looking at but needs to be able to handle duty cycle for 3 homes.
/ Automatic gate openers #6
If you do not want a swinger gate, then use the garage door opener system as a SLIDER.
It will work way faster than the video below.
Already have the duel swing gates as mentioned in the opening post.
/ Automatic gate openers #8
Have you considered Viking? Not inexpensive, but they have some high duty cycle options that might meet your needs, e.g. the G5 100% duty cycle;
All the best, Peter
All the best, Peter
I haven't. Will take a look. Thanks.
Jeremy
/ Automatic gate openers #10
Had my gates custom made and used Nice brand openers. Solar powered with keypad and two driveway sensors.
/ Automatic gate openers #11
Some food for thought.
Make sure the electronics are pest(slug) proof. A slug track shorted the mother board(mobo) out and the wait list was several weeks.
/ Automatic gate openers #12
Mouse piss will do the same thing.........
/ Automatic gate openers #13
US Automatic is what we use for our 2 8' gates. Our current model is the Patriot solar powered. We had the Ranger at first but switched it out when one of the arms went bad after 2 years. I still have it in case we add another gate for a secondary exit.
New Holland TS6030 (A64119)
New Holland TS6030...
Landhonor FW-13-15000G, Skidsteer Mount Winch  (A62679)
Landhonor...
2005 Jeep Grand Cherokee SUV (A59231)
2005 Jeep Grand...
2014 Nissan Murano Cross Cabriolet AWD SUV (A61574)
2014 Nissan Murano...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
Hobart Champion 16 AC/DC Engine-driven Welder and generator (A63689)
Hobart Champion 16...
