O-ring Boss Elbow Fitting Question
/ O-ring Boss Elbow Fitting Question #1
threepiece
Farmington, Mi
Kubota L3400 John Deere110 TLB Wheelhorse 520H
Fellows, I am trying to specify fittings and lines in an area that some might consider tight. An elbow such as the one pictured below would be ideal however it must point within a very few degrees of the plan.
Is there some method of fixing these in a particular orientation or are they limited to where they bottom out?
Thanks for any help,
Dan
/ O-ring Boss Elbow Fitting Question #2
That hex nut you see there, it's a jam nut. So you screw the fitting as far as possible, rotate to your desired angle, then tighten the jam nut to lock it in and provide the seal (note the o-ring).
I found a post that describes the jam nut. It has a clearer picture. Thank for helping to confirm.
/ O-ring Boss Elbow Fitting Question #4
When you screw the fitting in Try to keep the O-ring in area without threads. This allows the O-ring to seal on a smooth surface and less chance of O-ring being deformed in the threads
/ O-ring Boss Elbow Fitting Question #5
Do what PTSG said. He gave you the proper installation instructions.
What you’re doing is exactly what that fitting was made to do.
So, what you building??
Farm Hand Silage Wagon on John Deere Running Gear (A65640)
Farm Hand Silage...
53ft Dry Van Trailer (A65563)
53ft Dry Van...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
Mayrath 10" x 34' Truck Auger (A66285)
Mayrath 10" x 34'...
Quick Attach Backing Plate (A65579)
Quick Attach...
2017 Ford Fusion Sedan (A64557)
2017 Ford Fusion...
