New to me PT425
/ New to me PT425 #1
jwangelin
Member
Glenwood, NY
Bolens HT20
So I’ve been lurking on the forum for some time now and finally decided to pull the plug and get a used PT425. It came with a bunch of attachments and I’ll soon be hooking them up. It will take a bit of seat time to get comfortable in it. It has the rare and desirable Subaru Robin (hahahhahahaha) in it. I did find out after mowing that the cooling fan is toast. It wouldn’t kick on and the blade bearings are stiff. Is there a common fan or upgrade that is available?
Thanks,
Jon in WNY
/ New to me PT425 #2
Welcome!
My two cents is call Terry in service for the exact model fan. Power-Trac usually uses Spal fans. Occasionally, the temperature switch fails, so I would check that the fan does/doesn't function when 12V is applied directly to the fan.
All the best, Peter
/ New to me PT425
Welcome!
All the best, Peter
Unfortunately the temp switch was tripped but nothing. Also, the blades are hard to turn.
/ New to me PT425 #4
Welcome to the PT world! ;)
My fan, after sitting all winter, would not spin. I took a stick and rotated the blades around by hand many times in alternating directions until if freed up enough to spin with 12v. Had it not gotten free enough, it was gonna be new fan time.
Also, my thermostatic switch for the fan died about 15 years ago. I hooked up the fan to keyed 12v so it is always on.
/ New to me PT425
Crud, I was ready to call in and order a new fan but now I’m second guessing myself. Hopefully that will work. Thanks!
/ New to me PT425 #7
I also replaced the fuse in the fan line because it blew when the fan stuck.
I've also blown that fuse from a stick getting in the fan and stopping it.
/ New to me PT425 #8
If the bearings are stiff, my experience is that doesn't bode well for longevity, though it depends a bit on whether the grease is old/missing, or there is gunk around the bearing.
Still, @MossRoad's zero dollar fix would be worth trying in my book.
All the best,
Peter
/ New to me PT425 #10
If you are planning to use the PT to mow a lot I suggest you look into another fan mounted on the side of the engine cage with blades rotating to suck heat out of the cage. I had to have a valve job done around 900 hours and am convinced it was heat related. Since installing the fan have had no issues and it runs better with no run on at shut down(although non ethanol gas may play a part in that too?).
/ New to me PT425
Well, the fan was definitely junk and I bought a new one from the folks at power trac. I’ll probably get a cheap secondary in the future. The next big project is getting an in-tank heater.
/ New to me PT425 #12
You might also consider the Wolverine silicone pad heaters. (Search the threads here)
All the best, Peter
2020 HYDREMA 922G HM ARTICULATING DUMP TRUCK (A65053)
2020 HYDREMA 922G...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
2019 Big Tex Gooseneck Low Pro Equipment Trailer (A66285)
2019 Big Tex...
FIFTH WHEEL PLATE AND MOUNT (A65643)
FIFTH WHEEL PLATE...
DooLittle XTM-8418 Trailer (A66285)
DooLittle XTM-8418...
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
