Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions?
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #11
Weld studs on pipe to match the skid mounts. That way you can put pipe on and off as needed.
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #12
Admittedly this was the part of my road that is just packed dirt. Which just turns into packed mud under the snow when it's above freezing.
Plowing snow in mud? Good luck.
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #13
If used just for snow, drop down to a cat. 1, rear blade. If turned around backward it would better than your HD blade.
It's not as bad as it sounds, but I do need to put some gravel on it. It's a project that was supposed to happen this year, but you know how that goes lol.
I'll keep that in mind, but I just spent a small fortune on hydraulics for this blade, so I hope I can get it to work.
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #16
I've welded pipes to cutting edge for plowing snow, despite what others say and think if you have access to a plasma cutter that works it's easy, clamp pipe in a stick of angle iron preferably as long or longer than pipe, use edge of angle as a straight edge dragging torch along edge, loosen clamps rotate pipe slightly and cut adjacent groove. Learned the harder way have plasma cutter consumables on hand or your going to be using a grinder to finish cut. Lol
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #17
I tried this last winter and it didn't work for my conditions. The shoes sunk into the road and caused the blade to dig in. Admittedly this was the part of my road that is just packed dirt. Which just turns into packed mud under the snow when it's above freezing.
If the shoes dug in, I think the round pipe will dig in worse. I'd look into making longer (like 12") skids mounted on the side.
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #18
Initially surprised me yrs ago cuz I thought the same thing. It doesn't really even plowing snow on thawed soft ground in my experiences. I think cuz the roundness of pipe for cutting edge spread out over entire plow length helps keep the plow from digging in. Provided your not exerting extra down force on pipes cutting edge.
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #19
This company sells very large (30" long) skids for snow blowers for soft conditions:
SHOP | ARMORskids®
/ Putting a 2.75" hardened steel pipe on rear blade for plowing in soft conditions? #20
I have a local guy that gets it from the oil fields. Cost me $35 for 9ft length 1/4" thick, 2 & 3/4" dia. J55 tool grade steel, schedule 80.
AI....J55 steel is not a "tool steel" but rather a low-grade casing and tubing steel specified by the American Petroleum Institute (API) under the API 5CT standard. It's primarily used in the oil and gas industry for shallow wells due to its low cost and wide application range, with a minimum yield strength of 379 MPa (55,000 psi) and a minimum tensile strength of 517 MPa (75,000 psi).
2020 DRAGON ESP...
2011 MACK CHU (PINNACLE) (A60736)
2011 MACK CHU...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
2021 FORD RANGER (A60736)
2021 FORD RANGER...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
2014 FREIGHTLINER CASCADIA 125 6X4 T/A MID ROOF SLEEPER TRUCK TRACTOR (A59908)
2014 FREIGHTLINER...
