L3710 Will not Lift Front End
/ L3710 Will not Lift Front End #1
Suburban Plowboy
FL
Kubota L3710
I put two rear remotes on my L3710 HST. It lifts things like logs just like it always did, but it will not raise the tractor's front wheels when I push it down.
What is the most likely problem?
/ L3710 Will not Lift Front End #2
Hard to say. What did you add and how/where did you add it? Something obviously changed if it raised the front end before the addition. More details or a lot of wild guesses come next.
I don't have a habit of lifting the front end with the bucket, having little reason to do so, so I am not positive, but I believe it was possible to lift it before I installed the new valves.
I'm going to make sure the fluid is topped off, and I will also go through the air-bleeding procedure I saw somewhere.
/ L3710 Will not Lift Front End #4
In most cases bleeding won't be necessary. What exactly are we doing here? Are you looking for answers concerning a problem you're "not positive" you even have? I don't know about others, but when I have questions about hydraulics, lifting or not lifting as expected I start with a pressure gauge plugged into a coupler somewhere, and see what that tells me.
/ L3710 Will not Lift Front End #5
If youre incidentally holding the brake when trying to lift .. dont.
/ L3710 Will not Lift Front End #6
When you try to lift the front, are you putting the loader all the way down, and then curling the bucket like you want to dump a load?
The hydraulic system should self-bleed.
I did not try to curl the bucket.
I will get back on this tomorrow. I am hoping my bearings and seal will be here by then.
I don't hold the brake. I can't recall ever using the brake. On this farm, I never need it.
/ L3710 Will not Lift Front End #8
I have a 3901 L doing the same thing,. dealership says hydraulic pump is bad and complete system must be replaced, The cost is $20,000. tractor has 160 hrs on the clock. I am looking for another tractor. The cost for my tractor new was $20.000.
That's horrible. I can't believe that's an honest estimate, but then I don't repair tractors.
My loader only has problems on the way down, and it didn't start until I installed the rear remotes, so I think my pump is fine.
/ L3710 Will not Lift Front End #10
My hyd oil has always ran VERY hot. I'm still waiting on a decision from K-Tek insurance. praying they will cover it. If not I'm stuck with a non functioning unit???
/ L3710 Will not Lift Front End #11
I think one zero is misplaced.
/ L3710 Will not Lift Front End #14
Please find another dealer that is not trying to scam you.
Highly unlikely that you need a new pump, but even if you did, that's like around $1300 or so. Kubota L3901HST (4WD TRA W/HYD TRANS/FOLD ROPS) Parts Diagrams
/ L3710 Will not Lift Front End #15
Hydraulic oil always ran VERY hot. Most people see that as a valve stuck open(or closed) somewhere that shouldn't be. Lots of restriction to oil flow where there shouldn't be. Those are the sort of things that destroy hydraulic pumps and can certainly do so in matter of hours if left unchecked. What do the mechanics have to say about probable cause? Have they found anything that might account for a pump failure? Have they even looked?
Good luck with insurance on that. Like claiming warranty on a dry clutch. A lot of people try, few succeed.
/ L3710 Will not Lift Front End #16
I wish it was as simple as that. do some checking and get back to me. If you can find a better price please let me know. I am patiently awaiting your info...
Are you the original owner? 160hrs?! It sounds like your tractor was delivered with a latent defect. Sue Kubota.
/ L3710 Will not Lift Front End #17
I know when I need to get my wheels off the ground I have to tilt the lip of the bucket to 90 degrees to the ground, then go straight down to raise the wheels off the ground, otherwise it barely lifts them.
/ L3710 Will not Lift Front End #18
Once they sucker someone out of that much money, they're emboldened to take the person for even more.
I'm going to feel stupid if I put the bucket back on and the front wheels come off the ground, but I have a feeling that's the problem.
/ L3710 Will not Lift Front End #20
In Missouri we say "Show Me!"
As a kid growing up in Vermont we use to say "try it, you may like it" ...
Either way I've found it's the best way to learn!
2017 Case CX145D (A60462)
2017 Case CX145D...
case 370 glass door never installed (A61306)
case 370 glass...
2025 40ft 10-Door Shipping Container (A59228)
2025 40ft 10-Door...
Kivel Quick Hitch Skid Steer Attachment (A59228)
Kivel Quick Hitch...
(15) WOOD PALLETS (A60432)
(15) WOOD PALLETS...
2022 KOMATSU PC130-7 EXCAVATOR (A60429)
2022 KOMATSU...
