L3710 Will not Lift Front End
   / L3710 Will not Lift Front End #1
Suburban Plowboy
FL
Kubota L3710
I put two rear remotes on my L3710 HST. It lifts things like logs just like it always did, but it will not raise the tractor's front wheels when I push it down.
What is the most likely problem?
   / L3710 Will not Lift Front End #2
Hard to say. What did you add and how/where did you add it? Something obviously changed if it raised the front end before the addition. More details or a lot of wild guesses come next.
I don't have a habit of lifting the front end with the bucket, having little reason to do so, so I am not positive, but I believe it was possible to lift it before I installed the new valves.
I'm going to make sure the fluid is topped off, and I will also go through the air-bleeding procedure I saw somewhere.
   / L3710 Will not Lift Front End #4
In most cases bleeding won't be necessary. What exactly are we doing here? Are you looking for answers concerning a problem you're "not positive" you even have? I don't know about others, but when I have questions about hydraulics, lifting or not lifting as expected I start with a pressure gauge plugged into a coupler somewhere, and see what that tells me.
   / L3710 Will not Lift Front End #5
If youre incidentally holding the brake when trying to lift .. dont.
   / L3710 Will not Lift Front End #6
When you try to lift the front, are you putting the loader all the way down, and then curling the bucket like you want to dump a load?
The hydraulic system should self-bleed.
I did not try to curl the bucket.
I will get back on this tomorrow. I am hoping my bearings and seal will be here by then.
I don't hold the brake. I can't recall ever using the brake. On this farm, I never need it.
   / L3710 Will not Lift Front End #8
I have a 3901 L doing the same thing,. dealership says hydraulic pump is bad and complete system must be replaced, The cost is $20,000. tractor has 160 hrs on the clock. I am looking for another tractor. The cost for my tractor new was $20.000.
That's horrible. I can't believe that's an honest estimate, but then I don't repair tractors.
My loader only has problems on the way down, and it didn't start until I installed the rear remotes, so I think my pump is fine.
   / L3710 Will not Lift Front End #10
My hyd oil has always ran VERY hot. I'm still waiting on a decision from K-Tek insurance. praying they will cover it. If not I'm stuck with a non functioning unit???
MERCURY VERADO ENGINES (A55758)
MERCURY VERADO...
Mini Margaritaville Truck (A55853)
Mini...
2018 KUBOTA SVL75-3 SKID STEER (A52709)
2018 KUBOTA...
Mower King Brush Cutter (A53317)
Mower King Brush...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
2014 Ford E-450 Super Duty Shuttle Bus (A56858)
2014 Ford E-450...
