Repairing Drilled Engine Block
/ Repairing Drilled Engine Block
Why are to trying to save this old block? Even if a reliable fix were found, you'd still have the original spun bearing issue to fix. Cost prohibitive, IMHO.
The other block has a crack and is 2k to fix
Interesting thread with a lot of good fixes, however, something isn't Kosher.
I work part time at an authorized Kubota dealer and I know for a fact that if you buy a reman engine from Kubota, for any reason or even a short or long unused engine, Kubota has to have documented proof the original engine was destroyed and rendered not useable or rebuildable. Documented proof for Kubota is detailed pictures of the destruction and or valid receipts from a scrap company.
I've destroyed more than one failed engine and in my dealer's case, that involves using a sledge hammer or torches and destroying it, not drilling a hole in the block that can be repaired. Like I said, Kubota requires documented proof as in pictures or scrap dealer receipts that the engine was rendered not useable or repairable, except for scrap value. Corporate policy. I have no idea about an independent non Kubota rebuilder or shop, only a Kubota authorized dealer.
The OP in his first post states a Kubota dealer drilled the hole and I'm very suspect of that.
Kubota revised and adopted that policy when the emissions engines came on the scene to prevent an owner of a failed engine replacing it with a non emissions engine.
Give me no pleasure in destroying a rebuildable engine but corporate policy is corporate policy anyway and at least the dealer I work for don't want to loose his franchise over an engine.
I will say, using a 15 pound sledge on one renders it junk real fast. That and using it for target practice with a high velocity round.
If you buy a long block from Kubota you cannot remove anything, a short block, you can. Not sure about other brands, just Kubota.
You can suspect all you want but the drilling was done by a large kubota dealer
And yes, the kubota mechanic that is helping me with this project on the side says they now have to destroy engines beyond repair
Question....if the hole goes through to cylinder wall is it below the ring travel? If so thread the entire hole and insert threaded rod with sealer....otherwise junk it...
I personally would not buy a Kubota, no offense to anyone but they work too hard to do things like this. As another dealer at one time I saw too many small Kubota owners coming to me with tractors that ran hot with scalded piston walls and no sleeves....
No. It right in the middle of piston stroke
When you go to get parts for the rebuild and give the engine serial number, it’s going to raise a red flag showing the engine was “destroyed”. Kubota could come back to the dealer and give them a very hard time.
I'm never going back to any dealer for engine work
How far down, from the top, is the hole drilled? If it is like halfway down, outside of the combustion chamber and below ring travel, why not just JB Weld it and give it a good honing, as long as nothing passes over it other than the piston skirt?
In the middle of the piston stroke
So, once you spend the money to fix the "destroyed" engine, what do you plan to do with it, keep it as a spare or sell it?
Trying to figure out which way to go as other block has a crack in it
Maybe he is wanting to make some money on Craigslist or Ebay by selling it? Probably not, since he is considering fixing the hole in the block! A lot of those sellers just describe it as "Runs Good" and forget the hole! (Can you tell I recently had a bad purchase?)
David from jax
If that serial number on the block is ever required for parts or service, there could be some grief for the "last one" holding the bag. Between that and an expensive repair process, I would be VERY WARY of going through with your plan. If EPA required them to do this, they (kubota) will be loath to get crossways with them (EPA). And do you plan to offer full disclosure to the next owner of that engine if it comes to fruition. I wouldn't do it.
This tractor will never see the service area of a dealer again
Agreed. I'd be more worried and pissed about the time I wasted in rebuilding a questionable block, not worrying about serial numbers.
If you want a spare motor, I'd be shopping for one out of a junked tractor, before ever pouring time and money into a drilled block with a spun main bearing.
Got a good spare kubota V2403 engine you wanna sell me?
/ Repairing Drilled Engine Block #73
haha... nope! Is it a hard one to find?
I just opened a search window, and entered "tractor salvage kubota V2403 engine", and the first few hits showed rebuild kits at $500, used engine at $1900, and new engine at $2800. If truly available, I couldn't see putting machine shop hours + my hours + $500 rebuild kit + $500 in other random parts and consumables, all into an engine I could replace for under $3k.
Is this pricing valid, or bogus?
It's valid if you want a chinese rebuilt engine in your tractor
/ Repairing Drilled Engine Block #75
I had almost the same issue on my old Massey. Since I didn’t want to risk messing things up more, I looked for a used block on Ovoko and ended up finding one in better shape than mine. Swapping it was easier than trying to fix the mess. If you’re stuck with cracks or deep overdrilling, it’s worth checking there before putting too much time into patching.
/ Repairing Drilled Engine Block #76
Stainless MIG wire welds to some types of cast iron just fine. I've done it.
I bought a 3-phase motor on Ebay, and the seller jammed it into a flat-rate box with no padding. The USPS punished him, and me, by dropping it and breaking a corner off the base. I'm sure it was an accident. :rolleyes: I got a refund, and then I decided to see if the base could be fixed.
People told me to try stainless wire, so I did. I warmed the cast iron up with a torch and then welded the parts back together. The welds held up fine in spite of being in a location that takes some stress.
/ Repairing Drilled Engine Block #77
For a guy who wears a black belt and has 2 dobie companions you sure play the victim a lot.
Eric
/ Repairing Drilled Engine Block #78
Me: I got a free 3-phase motor.
You: You're playing the victim.
/ Repairing Drilled Engine Block #80
Sober up and come back to see if that still makes sense to you.
John Deere 700 H Dozer (A62679)
John Deere 700 H...
2006 JOHN DEERE 700J LT CRAWLER DOZER (A65053)
2006 JOHN DEERE...
UNUSED PARBREAK RGB240-79" HYD ROCK GRAPPLE BUCKET (A65055)
UNUSED PARBREAK...
2020 Ford F-150 4x4 Ext. Cab Pickup Truck (A64194)
2020 Ford F-150...
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
UNUSED FUTURE MINI EXCAVATOR ATTACHMENT SET (A65055)
UNUSED FUTURE MINI...
