Wanting to "cut" a slot in the ground
   / Wanting to "cut" a slot in the ground #1
dnw64
SE Vermont, South Jersey
Kubota B3030 Cab
I'm envisioning a disc that rotates, attached to the side of a bucket, so that when lowered and driven along, it makes a cut in the ground.
This would be to install edging, to keep a mulched area separate from the lawn, so I would want to go approximately 3-4" below grade.
Firstly, is there such a thing commercially available? I've done some searching but have no idea what it might be called. The closest I've found is a "pipe layer", but one key factor is that it needs to be at the side of the tractor. Between my son and I we could probably modify something if it was out there.
If not, any ideas/suggestions as to how one might be made? I have immediate use to install about 300LF of edging, and a lot more in the future, and don't look forward to doing this all by hand...
   / Wanting to "cut" a slot in the ground #2
It’s called a trencher. What is your exact use? How far do you have to go? Would one of those sidewalk edgers work? Some of those are gas powered on wheels.
   / Wanting to "cut" a slot in the ground #3
Good point one of them would work, bet there used ones readily available
Just in case here is a random pic of one
   / Wanting to "cut" a slot in the ground #4
If you decide on an edger don't get one with a vertical engine because the belt will need to have a twist in it to power the blade. It will eat belts. Get one with a horizontal output shaft so there doesn't need to be a twist in the belt.
   / Wanting to "cut" a slot in the ground #5
Maybe look at silt fence installing attachments for ideas.
   / Wanting to "cut" a slot in the ground #6
Our local sod installation company uses a blade on a weed eater set at a 90 degree angle to cut and trim sod during installations, carving out flower beds, etc...
The local university has this on a Toro Workman. It's just a disk with pressure. Works well.
I have my old Craftsman electric edger that I've had since 1985 if I need to edge the driveway.
I have a plowshare set on a quick attach plate that I use to trench in poly pipe into the ground about 8" deep. That would work to slice and edge for edging.
Most of the time I just use a tool like this...
   / Wanting to "cut" a slot in the ground #7
I use a Mantis with an edger blade.
   / Wanting to "cut" a slot in the ground #8
A plow coulter would possibly do what you want. Cheap to try as used ones abound.
Would also be easy to mount to side of your bucket.
   / Wanting to "cut" a slot in the ground #9
I've had a belt drive McLane I've used at the house for years. Yeah, I've gone through 3-4 belts over the course of about 10 years, but I'd consider the cost vs. use in buying one. Belts are cheap, and the link ones are easy to change out.
   / Wanting to "cut" a slot in the ground #10
Do you have a picture of this? It sounds like it might be what I need.
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
40' x 20' All Metal Carport (New/Unused) (A59225)
40' x 20' All...
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
2025 YOU-380 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attachments (A59225)
2025 YOU-380 Mini...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
